The Meguiar s APC works. I’m sure the CarPro APC will work also. I believe it’s called MultiX.
Printable View
Thanks I found a gallon of the Optimum APC for $40, maybe I should invest in it an add it to the washer machine to all washing cycles as well? As a booster to the regular microfiber detergent, which is ph balanced so doesn't seem to work so well with waxes and sealants
For what other applications do you use Optimum APC? As wheel clener, interior, maybe as bug&tar remover?
I think it would be a good addition if I'm trying to keep it simple for maintenance washes... Just regular wash & wax soap for foam cannon and bucket, Optimum No Rinse as water softener in wash bucket an diluted in spray bottle as quick detailer and Optimum Power Clean for interior, microfiber detergent booster and stubborn bugs on paint/glass, maybe to spray tires before scrubbing with brush
