Hi David! Apologies for the delay in response - Just saw it. Luckily we have great guys like Chris here to save the day!! That is why we made a forum right!!?
Here is my bit of help as well -
1) Now that it is cured take a dot of reflect on a foam applicator pad by hand and literally just wipe it once back and forth with no pressure and then wipe the polish off with a very soft towel. If its gone, great! if not wipe once more. (If you don't have Reflect, then a fine finishing polish should suffice) These high spots are usually very easily removed with the abrasives in a polish and how easy to remove or how easy to remove too much coat changes the more it cures. As Chris said, you can also apply another coat over that panel again if you think you polish too much off. If you had streaks everywhere then a fast go with the d/a could be in order but just a couple is super easy by hand.
2) I do not dilute it personally. I don't think its needed and have actually never tried it that I recall! Some do... If you use my technique with two towels and immediate wipe on, buff, in, wipe off and then follow with the "secondary towel" (which is the one you keep dry throughout for only final wipe) then you should have no streaks. The key is to remove streaks as you go... don't wait till you are done with the car to start looking for them. I have a video coming next week for Reload application! Shot a month ago but finally freeing up time to get these things done!I use a yellow fellow original to apply, buff in, and wipe, and then a crazy pile for final buff on each section before moving on. Flawless!
3) No, and yes, The coating will NOT be affected however soap, QD, and detailers can allow a film to affect the behavior of dust, dirt, and water on the coating. This is easily remedied by a wash with CarPro Reset at any time however and it will "Reset" the coating. SO in conclusion (if this helps) I do NOT hesitate to use Ultima Waterless Wash (as my QD spray) - I use it all the time... and I wouldn't hesitate to use the one you mentioned either as I'm sure its a dandy QD!
Best,
Thanks Corey for the response.
Reflect with a hand applicator worked well to rid of the haze marks. Do you believe there are enough abrasives in Reflect that may have stripped off some of the protection properties of the newly applied CQuartz?
Certainly it may have stripped some, depending on how long it cured and how hot it got during the first few hours of curing it will have removed more or less but if you wiped gently and only as needed then it should still be fine. If it's a customer car I just reapply another coat over the panel I fixed to be safe in ending up even thicker instead of any possibility of thinning. If it was my car and looked perfect after that trick I slap some reload on and call it a day.
It looks very forgiving -- longer work time -- than previous video's I had seen.
This is how it works for me. I have no problem waiting a few minutes. - For some they tell me they have to wipe off right away which is fine. You can wipe off immediately after applying... So no need to flash. Very forgiving indeed if the tips I verbalized are followed. i.e. changing out suedes, etc.
HI Corey,
I want to say you thanks for your CQ video becouse I used it in my first CQ application and you gave me a lot of tips and showed to incompetent user like me how simple could be this product.
I'm from Italy and I follow the most local important detailing forum (LCDA) with thousand of users. I posted the link of your CK application video to help also other dummies and one of much famous italy pro-detailer said that in the video you used too much product and you didn't remove the eccess in the right way. He said also that if you used a flashlight you'll find a lot of stubborn haze marks left over.
I disagree with him but I am noone to say anything. Can you give me some good point to reply?
Anyway thank you for your videos that helped me very much and sorry for my bad English.
Hi Thriller! First, please don't apologize for englishWe are honored to have you here and you can believe you may speak better english than some of us
Thank you for your post! A few things... He is correct you can use much less product BUT for me it is very easy to apply it in the manner here. If you use less then it can dry up and become sticky faster (at least in our environment - Florida) So for me, this works very well this way. Also, if I apply a POINT light at the paint immediately after application it is true that I will see "holograms" from the carrier fluid BUT I NEVER see this after the solvents evaporate and a few hours pass. SO, its possible his environment is different and it won't work for him but I believe I can go to italy and follow similar process in front of him and achieve results he loves. ONLY difference... Depending on the environment I MAY wipe the product back off immediately instead of waiting a bit like I did in the video. Many people here in USA also must wipe off immediately from what they tell me... But I also believe they use too little product or something maybe. I have used before less product and one thing I can say is there are many ways that work.
The main point with CQUK:
Keep switching to a fresh applicator
Always wipe off all residue before it becomes sticky
Have good ambient lighting so you can make sure you removed all residue
Points that vary with environment:
How much you use
How soon you wipe off
