Dr_Pain
Is it going to rain all day? or did you just have a quick sprinkle? Personally I would not allow water to dry on the coating. It is going to be a pain but you need to keep it dry. Having said that (and what I mentioned before) it is possible that NOTHING will happen to the coating. If that is the case then you dodged the bullet. If you are left with imprints then a light polish and recoat is recommended. You may be able to remove the imprints easily (since the coating is fresh) but the polishing does disrupt the outer matrix and definitely benefits from a recoat. (the light polish won't take you all day, not like when you remove swirls and scratches)
