Originally Posted by
fdresq4
When applying something totally new, especially Reload for the first time, I like to decon with the two you mentioned. I like to use a clay alternative but nothing wrong with clay either. Some guys on here will use Iron X paste a lubricant with a Polyshave towel or block. Just be aware that you "may" introduce some swirls with deconning.
The 2014 version of Reload had issues with streaking but I have not had any issues with the 2015 and newer batch.
A light is handy to have but if you see a streak, grab a damp clean towel and even it out. Buff with a clean dry to follow up.
I'm guessing you have the Iron X spray? Decon with that prior to using clay. That will remove a lot of ferrous material.
