Originally Posted by
The Guz
Good looking Malibu you have there. This body style is a definite upgrade than the previous generation.
I will say to give Essence a go as a test spot. It will amp up the gloss even more and have less oils than Ultimate Polish.
I would still recommend an Eraser wipe when using Essence prior to coating the paint.
Thanks Guz, a lot of hard work went into getting it that far. It was really swirled-up from the dealer. The Meg's products have performed excellent but I want more and with less upkeep. I have the CQUK 3.0 and maintenance products already and will be applying it most likely in September. Trying to learn all I can about the CarPro line prior to doing so.
As for the Essence and Eraser, i've pretty much decided that's the way to go according to my research of the product. I'm an old-school guy and quite cautious at my age as well as a bit OCD.
Without starting a new thread, I have a few questions regarding maintenance products.......
1...As I said, I already have the necessary CarPro products but also a bit of Meguiar's also. Can Meg's Ultimate Quik Detailer be used in any way with the CQ?
2...I have Reset but will Meg's Gold Class Soap play well with the CQ?
3...Can any Meg's product perform the same function as CarPro's Spotless? This I do not have as of yet.
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
1. You can use the Megs Q.D. with UK. With that said, I would wait before using it on the coating, allowing the coating to fully cure. Just not sure if it has anything “extra” in it.
I’m sure the others can answer that better than me.
You mentioned having other Car Pro products, have you tried Echo 2 yet as a q.d.?
2. Yes but no soap on the coating until 7 days. Try to avoid soaps with waxes. Sometimes those additives may interfere with the coatings characteristics. You can use soaps with waxes but the coating kicks butt!
Using Reload or Hydro 2, or Merlin’s Magic Elixir is a different story...
3. That I cannot answer. I use Spotless so I’ll defer to the others here...
fdresq4
Thanks I just didn't want to let the Meg's Detailer go to waste. I have ECH20 on order and will give Merlin's Elixir a shot, as I was reading about it in another thread.
As for the Meg's Gold Class soap, i'm not 100% sure if it has any waxes in it but no biggie as I have Reset.
What are you looking to accomplish with Spotless?
I’m not 100% on Megs Gold class but it may be a “wash and wax” in one.
I’d stick with Reset for washing. They are made to work together.
Post Thanks / Like - 1 Thanks, 1 Likes, 0 Dislikes
dman68
In reference to question 2, if it’s the Megs G7164, it says it has “conditioners” in it. I would be hesitant then.
Hi Merlin, nothing with Spotless at the moment but looking to the future when I may have to use it. Since i'm gonna be switching to the Ceramic coating, I have a number of Meg's products that may go to waste if they cannot be used in any other fashion.
fdresq4
Yep, that's it. I'll just dedicate it to wheel soap then.
Thanks guys
Junior Member
Good info in this thread. I am also looking to coat my car using CQUK 3.0 in a few months once the weather cools. My current products are mostly Meg's as well, including a gallon of Megs Gold Class that I just got a month ago.
Looking to take advantage of the coating and the lower maintenance it might offer. Probably one more detail on my 2018 Accord, topping off with Meg's 2.0 Tech Wax, then will try CQUK 3.0 in the fall.
BTW dman68, your Malibu looks great!
bojo
Thanks bojo! Looks like we are in the same boat with planning the last detail.
