Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Which one works best for small scratches in clearcoat?
  1. #11
    Nov 2018
    24
    Thinking of getting the Porter-Cable 7424XP. Any suggestion on this one or another one.
  2. #12
    Senior Member rlmccarty2000's Avatar
    Nov 2015
    126
    I would get the Griots 6 inch polisher. It has more power and has a lifetime guarantee. Check around for the best deal. They are sold at some of the auto parts stores at a significant discount. Many of the detailing stores don’t offer discounts on polishers, but the parts stores will offer up to 25% off and their starting price can be better. I believe Griots Garage is offering a 20% discount on everything for Black Friday too.
    The Devil is in the Details.
  3. #13
    867
    I started out with the PC7424XP and it is a capable machine. It is a good starting point as is the Griot's polisher. Hard to turn down the warranty from Griot's. Be sure to get yourself a 5" backing plate with either machine and some 5" pads. That will set you up nicely.
    I like the smoothness of the Rupes Duetto over the PC7424XP but it may be out of your price range.
  4. #14
    Nov 2018
    24
    Ended up buying a slightly used griot's 6" polisher hd with the 25 ft cord. Also will have 3 backing plates a 3",5" and 6" that will come with it.
  5. #15
    Nov 2015
    126
    I would concentrate on the 5 inch pads and skip the 6 inchers. The Griots is a good polisher with plenty of power. Enjoy!
  6. Likes The Guz liked this post
  7. #16
    Nov 2018
    24
    will be getting 5" pads and will probably get some 3 1/2 of 4" pads for tight areas. Maybe for the rims and plastic front spoiler with dlux coating.
  8. #17
    24
    If the scratches on your 2013 Challenger are small and don't seem to go through the clearcoat, then you can use a scratch repair product like Fixer, Essence or Reflect to try and fix them. However, it's not necessary to use all three products in sequence. The choice of product will depend on the severity of the scratches and the type of finish on your vehicle.
    Fixer is designed to fill in light scratches and scuffs, so it might be the best option if the scratches are not very deep. Essence is a polishing compound that can help restore the shine and luster of your paint, so it might be useful if the scratches have dulled the finish. Reflect is a protective coating that helps prevent future scratches and provides a long-lasting shine.
    To determine the best approach, it's best to start with Fixer to see if it can fill in the scratches, and if it doesn't work well, you can move on to Essence or Reflect to try and improve the appearance. Keep in mind that even with the best product, it may not be possible to completely remove the scratches, and you may need to have the paint professionally repaired or repainted.
  9. #18
    Dec 2023
    What prompted your decision to choose the Griot's 6-inch polisher over the Porter-Cable 7424XP, and how has your experience been with the Griot's polisher so far?
  10. #19
    Jan 2024
    What specific features or aspects of the Griot's 6-inch polisher led you to choose it over the Porter-Cable 7424XP, and can you share your experience with the Griot's polisher since your purchase?
  11. #20
    Jan 2024
    What influenced your preference for the Griot's 6-inch polisher instead of the Porter-Cable 7424XP, and how has your experience been with the Griot's polisher so far?
