Results 1 to 2 of 2
Thread: Tar-X Safe on Coating?
    Junior Member Kingsford's Avatar
    Aug 2015
    15
    Question Tar-X Safe on Coating?
    Some how I got a ton of tar on the side of my truck which is coated with Cquartz UK.
    Is it safe to use Tar-X on it or will the Tar-X remove the coating?
    If it does remove the coating, what would be the best direction to go to remove the tar without compromising the coating?
    867
    You could try it and see if it affects the coating. If it does then you can touch it up with Reload or Essence Plus until you are ready to recoat.
Tags for this Thread
