Chemical Decon
Just to be on the safe side with a coated car, should IronX be used after a long road trip of a few thousand miles?
IronX can be used on a coated car. It is chemical decon.
You should NOT use a clay bar or alternative (polymerized rubber).
Anything in the form of mechanical decon can/will affect the coating.
Post Thanks / Like - 1 Thanks, 1 Likes, 0 Dislikes
Thank you sir.
Stick with the after care tips and you will be fine.
Coating Maintenance:
- The best thing to do is start using CarPro Reset to wash with regularly. Other soaps can leave residue that temporarily messes up the beading and allows dust and dirt to stick more readily.
- Wash Mitt:
- Microfiber Madness Incredimitt
(Recommended for daily drivers and most cars - This mitt is easiest to maintain and is extremely durable as well as washing out most easily)
- Merino Wool Wash Mitt (Recommended if car has extremely soft paint or car does not get extremely dirty)
- Drying Towel: CarPro or Microfiber Madness
- Quick Detailing
: CarPro ECH2o Concentrate and Microfiber Madness Crazy Pile towels (need about 3-6 towels)
- Occasionally (every 3 to 6 months) decontaminate surface with CarPro Iron X. Use during wash cycle (after Reset) and as directed
- If using CarPro Reload as topper: use every 3-12 months, for special occasions or any time you like.
Post Thanks / Like - 1 Thanks, 0 Likes, 0 Dislikes
