Results 1 to 9 of 9
Thread: Essence over Cquartz
  1. #1
    Junior Member
    Aug 2019
    9
    Hi guys , i need some advice , my car has been coated 1 layer , but bird bomb hit my hood , so i take a wet mf to erase bird bomb , its gone but my hood look haze after that and look so many swirl while erasing bird bomb .
    Can i took essence and top it again with cquartz uk ?
    Sent from my SM-G975F using Tapatalk
  2. #2
    Nov 2016
    866
    Welcome to the forum.
    Is the swirling on the entire hood?
    To answer your question yes you can use Essence and re-coat after.
  3. #3
    Junior Member
    Aug 2019
    9
    Yes entire hood ,
    Would essence remove all cquartz uk that has been cured 2 days in outside sun ?
    34d celcius here .
  4. #4
    Nov 2016
    866
    You will have to do a test spot. But it should remove it.
  5. #5
    Junior Member
    Aug 2019
    9
    Alr tested , all panel is more deep glossy .
    One more question , better use carpro mf pad or megs mf pad for essence application ?
    And the last one is denim pad , my paint is so soft , what best combination for denim pad ?
  6. #6
    Junior Member
    Aug 2019
    9
    Right , because that , i want to remove orange peel factory from my another truck
  7. #7
    Junior Member
    Aug 2019
    9
    Guys , i need some advice . Can i use megs m34 final inspection top cquk 3.0 , gliss and reload ?
  8. #8
    Nov 2016
    866
    Quote Originally Posted by teknikjayaperkasa View Post
    Just don't use it between steps of applying CQUK and Gliss. Other than that it will work fine.
  9. #9
    Junior Member
    Aug 2019
    9
    Ok thank you bro
