Thread: Carpro hydro2 query
    May 2020
    Carpro hydro2 query
    Hey,
    I am having a query. I have applied 2 layers of carpro cquartz uk 3.0 on my car. But I don't have reload, so can I apply carpro hydrO2 as a spray sealant. If I can then I spray hydrO2 and wipe it out or spray it wash it with pressure washer.
    710
    Quote Originally Posted by Sunny Sidana View Post
    Hey,
    If the coating is fresh itís best not to get it wet. Save hydro for the first wash.
    How long has the coating been on?
    May 2020
    Coating is still fresh.. I have applied it around 10 hours ago.
    1,218
    Sunny,
    Taken from 3.0 “Tips” section...
    Tips:
    Keep surface dry for at least one hour after application (For best results keep dry 24 hours).
    Gently wipe any water off the surface during the first 24 hours after application.
    Avoid detergents and chemicals for 5 days after application.
    If it is dry and the air is clean outside then you may park the vehicle in direct sun after application to speed the curing.
    I wouldn’t chance it with Hydro 2 because of its application process.
    As Guz mentioned, wait for another time to apply..
  5. Likes The Guz liked this post
