Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: How to restore Dhydrate towel abosrbency?
  1. #11
    Junior Member
    Jan 2023
    1
    Designed to easily slide across the vehicles surfaces, the Dhydrate towel good way to remove absorbency
    Our orahome private label manufacturing services are offered to bulk clients who wish to be a trendsetter and not like the rest.
  2. #12
    Junior Member
    Jun 2020
    24
    Here are a few steps to restore the absorbency of a dehydrated towel:
    Soak the towel in warm water: Fill a sink or a bucket with warm water and submerge the towel. Allow it to soak for at least 30 minutes.
    Wash the towel: Use a mild detergent and wash the towel on a gentle cycle. Avoid using fabric softeners or bleach, as these can damage the fibers and reduce absorbency.
    Rinse the towel thoroughly: Make sure to remove all traces of detergent from the towel by rinsing it several times.
    Dry the towel: Tumble dry the towel on a low heat setting or hang it up to air dry. Avoid using high heat or over-drying the towel, as this can damage the fibers and reduce absorbency.
    Use it again: After following these steps your towel should be back to its original absorbency.
    Note:
    Microfiber towels are more likely to lose their absorbency if they are washed with other materials that have lint, like cotton towels.
    Avoid using fabric softeners or bleach while washing microfiber towels, as these can clog the fibers and reduce absorbency.
    Always read the manufacturer's instructions before using any products.
  3. #13
    Junior Member
    Jan 2024
    1
    How has the effectiveness of the Dhydrate towel been for you, and have you encountered any specific challenges or successes with the orahome private label manufacturing services for your bulk orders? Additionally, have you tried any other methods to restore absorbency in towels aside from the ones mentioned?
