Thread: Can Uk 3.0 be layered over SIC
    May 2021
    10
    This is first time using carpro ceramic I applied 2 coats of Uk 3.0 let it set 24 hrs then applied Sic and had issues with the flashing and buffing off the Sic. There were blotchy high spots all over. I applied a second coat of Sic and buffed off while it was slightly wet still to remove the high spots which worked. I just skeptical now in doing this did I compromise the original Uk 3.0 I put on. I still have enough Uk and Sic to do a coat of each. Is it ok to apply Uk3.0 over Sic?
    You are perfectly fine. The SiC did not compromise the UK.
    May 2021
    10
    Thanks I have half a bottle ok UK so I figured maybe use it up and add a coat or 2 since the bottle os only good a year. Is it ok to layer the remaining UK I have over the Sic or are these ceramics only able to be layered in specific order
