Results 1 to 2 of 2
Thread: HydrO2 Foam + MTM Hydro PF22.2 Snow Foam Cannon: what setting on cannon for 9:1??
    Jun 2022
    Hi, I will be buying HydrO2 foam and a MTM Hydro PF22.2 Snow Foam Cannon. How does one achieve a 9:1 dilution ratio running through a cannon? I can dilute the mixture I put in the cannon bottle at 9:1, but this means I will have to cut off any water from mixing with the mixture before it's sent to the vehicle. Curious as to what others have done with this setup?
    thanks!
    Paul
    Jun 2022
    After watching some videos online, it appears one just cuts it 9:1 and adjusts the cannon to max foam.
