Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: 2022 Tesla Model 3 - Pearl White - CQuartz Finest Reserve - 🌴 A Miracle Detailing
  1. #1
    Jun 2014
    1,902
    Inspection:
    Lighting:
    ScanGrip MultiMatch 8 and MultiMatch 3 color from 2500k to 6500k. ScanGrip Sunmatch 3
    Machines:
    RUPES Bigfoot iBrid Nano Long Neck
    RUPES BigFoot LHR 75E Mini
    Rupes 21 with a Rupes 5" Backing Plate
    Correction:
    Lake Country HDO Blue Cutting Pad - 5 1/2"
    Meguiars M110 and Megs M101 Ultra Pro Speed Compound
    Polishing:
    CARPRO Gloss Pad 5"
    Meguiars M210 Ultra Pro Finishing Polish
    Tools:
    RYOBI Cold Water Electric Pressure Washer
    Cleaning Products:
    CarPro IronX Snow Soap / Poorboys Super Slick & Foam Pre Wash Snow Foam
    Last Step Products:
    CQuartz Finest Reserve ceramic coating on paint, and wheels
    CQuartz Dlux Wheel and Trim Coating on plastic trim and bumpers
    Sonus Trim and Motor Kote (Dressing Engine Bay)
    CARPRO ReTyre Tire & Rubber Cleaner (cleaning tires)
    OBSSSSD Tire Dressing - Matte (dressing tires)
    Please watch the 360 walk-around video - Click bottom right YT Gear to set 1080p HD w/audio
    Hood Shot
    Front Drivers Side
    Rear Passenger Side
    Front Passenger Side
    The Front
    Thanks for Looking!
    https://www.linkedin.com/company/amiracledetailing
    Questions/Feedback is truly appreciated.
  2. #2
    Junior Member
    Aug 2022
    4
    The MTM Hydro PF22.2 Professional Snow Foam Cannon and the Metro Air Force Master Blaster are some serious tools!
  3. #3
    Junior Member
    Aug 2022
    3
    I haven't used TUGA Devil Special Wheel Cleaner before, but I'll definitely give it a try. ���� Oh, and I see you're using CarPro IronX Snow Soap and Poorboys Super Slick & Foam Pre Wash Snow Foam, both great products. ���� Your last step products are on point! CQuartz Finest Reserve ceramic coating is always a go-to for any serious detailer, and I love how you're using CQuartz Dlux Wheel and Trim Coating and Sonus Trim and Motor Kote to protect and shine all the different surfaces.
    Thanks for sharing your tips and tools with us! I'll be sure to check out topcarstesla.com for more inspiration! ��
  4. #4
    Jun 2014
    1,902
    Quote Originally Posted by klauswoolhouse View Post
    It's a "Do it once...Do it right."
    I've tried the less expensive products.
    I call it "The high cost of saving money."
  5. #5
    Jun 2014
    1,902
    Quote Originally Posted by accidentaljosh View Post
    I haven't used TUGA Devil Special Wheel Cleaner before, but I'll definitely give it a try. Oh, and I see you're using CarPro IronX Snow Soap and Poorboys Super Slick & Foam Pre Wash Snow Foam, both great products.
    Thank you for your kind words.
  6. #6
    Member
    Dec 2022
    35
    I notice you often use Iron X Snow Soap. Do you find the Iron X Snow Soap replaces the need for regular Iron X (or other Iron removers) to remove bonded metals so the coating adheres properly or sometimes you get cars bad enough you still need to use traditional Iron X?
  7. #7
    Jun 2014
    1,902
    Quote Originally Posted by BrentinLouisville View Post
    I like the Iron X Snow Soap for a prep wash because...it helps with "dwell time" to lift contaminants.
    After the prep wash, I test an area with regular Ironx. If there are still contaminants I spray down the car before rinsing and then "clay".
    I also use IronX snow soap to "wash/decon" paint that has a coating on it.
  8. #8
    Member
    Dec 2022
    35
    Quote Originally Posted by Merlin View Post
    Interesting, so when using regular Iron X, the Iron X Snow is still on the car and then you "clay" with with I assume some form of clay towel/mitt/ and the Iron X Snow is acting as your "clay" lubricant if I understand you? At first I would have thought the Iron X Snow would dilute the sprayed Iron X buy now that I think of it, really no more than spraying on a wet vehicle.
  9. #9
    Member
    Dec 2022
    35
    Delete, duplicate post.
  10. #10
    Member
    Dec 2022
    35
    Machines:
    Did your Rupes 21 come with a 5" backing plate or did you swap the 6" backing plate that came with it for a 5" backing plate?
