Results 1 to 7 of 7
Thread: Prep process to replace Gliss with SiC as a topper over ceramic coating?
    Junior Member Jim Holtz's Avatar
    Oct 2022
    3
    Sorry for the cross post but it seems there is little to any traffic in the CQuartz forum.
    Last spring I applied a ceramic coating on my cars followed with 2 coats of Gliss as a topper to help prevent water spots. It turned out great, and I'm very happy with the results. I love the look and slickness of Gliss but since Gliss has a one year life span, I'm looking ahead at applying SiC as a topper next spring to get the extra durability. I don't want to polish the car again and start over unless absolutely necessary.
    My question is, what do I need to do to prepare the surface to accept SiC over the existing Gliss coating or how do I remove Gliss to prepare the existing ceramic coating to accept SiC without removing the existing ceramic coating?
    Thank you for your help!
    Jim
    Nov 2022
    5
    I hope an expert will answer you on this
    Oct 2022
    3
    Quote Originally Posted by waelomar View Post
    Thanks for the follow up. I did contact the support desk by email and promptly received a message that I couldn't use CQuarts SIC over the top of Gliss without buffing the Gliss off and the ceramic coating I originally applied. I'm very pleased with the performance of the Gliss except for the longevity, so I'll just do the basic cleaning prep next spring/summer and apply a couple more coats of Gliss. Sometime in the future I'll want to start over. Then I'll reevaluate what I want to use then.
    Thanks again!
    Jim
    871
    Yeah agree with what support told you. SiC would be best applied to bare paint meaning polishing and using that as your source of protection. That goes for any of the actual coatings. You can add more Gliss after a decon wash.
    Nov 2022
    5
    thats great
    May 2024
    33
    If you're thinking about swapping out Gliss for SiC as a topper over your ceramic coating, here's a quick prep process: Start with a good wash to clean off any dirt, then strip away the old Gliss using something like IPA wipes. Give your ceramic coating a once-over to make sure it's still in good shape, and if needed, touch it up or reapply it. Finally, apply the SiC topper following the instructions on the bottle. It's a straightforward process that'll keep your ride shining bright!
    At Triple A Trading, I am dedicated to providing top-notch customer service, helping clients find exactly what they need, whether it's for routine maintenance, performance upgrades, or restoration projects. My goal is to ensure every customer leaves satisfied and confident in their purchase.
    Jun 2024
    16
    Hey Jim, you can prep your car by giving it a deep wash, followed by an iron remover to clear out any remaining contaminants. An IPA wipe afterward should help ensure the surface is ready for SiC without needing to polish again. This approach helps preserve your base coating while ensuring the new layer bonds properly.
