Results 1 to 4 of 4
Thread: 2022 Porsche 911 Carrera GTS - CQuartz Finest Reserve - 🌴 - A Miracle Detailing
  1. #1
    Jun 2014
    1,895
    Inspection:
    Lighting:
    ScanGrip MultiMatch 8 and MultiMatch 3 color from 2500k to 6500k. ScanGrip Sunmatch 3
    Machines:
    RUPES Bigfoot iBrid Nano Long Neck
    RUPES BigFoot LHR 75E Mini
    Rupes 21 with a Rupes 5" Backing Plate
    Correction:
    Lake Country HDO Orange Polishing Pad - 5 1/2"
    Meguiars M101 and M110 Ultra Pro Speed Compound
    Polishing:
    CARPRO Gloss Finishing Pad - 5"
    CARPRO Reflect High Gloss Finishing Polish
    Tools:
    RYOBI 1800 PSI Cold Water Electric Pressure Washer
    Cleaning Products:
    CarPro IronX Snow Soap / Poorboys Super Slick & Foam Pre-Wash Snow Foam
    Last Step Products:
    CQuartz Finest Reserve ceramic coating
    Carpro DLux on plastic trim and bumpers
    CARPRO ReTyre Tire & Rubber Cleaner (cleaning tires)
    OBSSSSD Tire Dressing - Matte (dressing tires)
    Please watch the 360 walk-around video - Click bottom right YT Gear to set 1080p HD w/audio
    The Merlin Shot
    Thanks for Looking!
    https://www.youtube.com/@AMiracleDetailing
    https://www.linkedin.com/company/amiracledetailing
    Questions/Feedback is truly appreciated.
  2. #2
    Junior Member
    Dec 2022
    19
    When you are dialing in your compound/polish combination, on average, how many test spots will you do before you feel you have the right combo? I am guessing you used 101 on one spot, 110 on another, a mix of 101 and 110 on a third and maybe a few more before deciding on the compound(s) you want to use. Once the car is compounded, do you go through a similar process for polishes? I.e., you 205 on one spot, 210 on another, etc..
  3. #3
    Jun 2014
    1,895
    Quote Originally Posted by BrentinLouisville View Post
    1) When you are dialing in your compound/polish combination, on average, how many test spots will you do before you feel you have the right combo?
    2) I am guessing you used 101 on one spot, 110 on another, a mix of 101 and 110 on a third and maybe a few more before deciding on the compound(s) you want to use.
    3) Once the car is compounded, do you go through a similar process for polishes? I.e., you 205 on one spot, 210 on another, etc..
    1)
    Every car/paint is different. Sometimes two or more test spots.
    2)
    I always start with the least aggressive method first! (machine/pad/compound/polish)
    M101 has more cut than M110. Sometimes I use Rupes Blue or Yellow compound.
    The pad also makes a big difference. It is the process of finding the right combo.
    Did I mention...Every car/paint is different! I use the least aggressive method.
    Pads:
    CARPRO Microfiber Cutting Pad
    RUPES DA Blue Coarse Cutting Foam Pad
    Lake Country HDO Blue Cutting Pad
    RUPES DA Yellow Fine Finishing Foam Pad
    and a few more...
    Compounds:
    Meguiars 101 Professional Foam Cut Compound
    Meguiars M110 Ultra Pro Speed Compound
    RUPES Blue DA Coarse Cutting Compound
    RUPES Yellow DA Fine Polishing Compound
    and a few more...
    3)
    Yes.
    Sadly, I have not used M205 much recently.
    Polish:
    Meguiars M210 Ultra Pro Finishing Polish
    RUPES UNO Pure Universal Ultrafine Finishing Polish
    CARPRO Essence EXTREME Gloss Primer
    and a few more...
    Pads:
    CARPRO Gloss Pad
    Lake Country HDO Black Finishing Pad
    RUPES DA White Ultra Fine Finishing Foam Pad
    and a few more...
    I'm always safely shooting for that swirl free, mirror finish.
  4. #4
    Junior Member
    Dec 2022
    19
    Thank you for the reply, also thank you for the information about how Megs M110 and 101 compare.
