2005 Honda Odyssey
R
richy
This vehicle belongs to my neighbour. I'm going to be doing 3 cars for him over the next 3 weeks. I have done this van twice in the past, the last time being 2 years ago when I coated it with Americoat. It did not hold up as well as the CQuartz products (and originally Opti Coat) that I have done for him in the past, so this time it was getting coated with CQuartz (original).
Here it is as it arrived:
The front end not only had these scratches, but the clear was peeling in a few places too. It had been repainted in the past...maybe not well.
This is his winter vehicle, hence the Blizzaks on it. It is being put away once I am done with it.
Check out the monster scratch!
Another 2 places (that had been painted) where the clear coat was peeling:
I did not do anything to the front bumper and I suggested he get it repainted due to the badly peeling clear on it. I'll coat it after at some point.
The starting point as always was the wheels. The tires were cleaned with Zep 505 and the wells were cleaned with LATA. The barrels were initially done with Tarminator, followed by Zep Citrus. The faces were cleaned with a combo of Zep Citrus and Megs HW. The barrels were shot with Aqua Bead.
The van was then washed using Megs HW followed by a decontamination wash of IronX paste. It was then brought inside and was clayed with a clay towel.
The paint was treated to a 2 stage process with the first step being M100 with a black wool TB pad using my 3401 followed by M205 using a CarPro Gloss Pad. The touch ups were done including those few areas with chipping clear. At least (hopefully) that will stop that from happening if it has a coating over it. The headlights and tail lights were given the same 2 step process.
The paint, head lights, tail lights, wheels and all glass except for the windshield were given 2 coats of CQ original. The tires were shot with OptiBond via my air gun and then leveled. The trim was done with DLux.
Here it is all done:
Here's that nasty scratch filled and coated:
Some reflection shots:
You can see how cloudy it was unfortunately:
I was just shy of 20 hours on this van. Comments are always appreciated.
Such a pedestrian vehicle for you Richy! LOL! Those American Racing wheel, did they have some defects under the clear coat?
Great documentation...thanks for sharing.
Great work, as always!
Im curious on your IX paste decon process. Do you include some sort of clay or decon block/glove/pad?
I know it works wonders as a lube, but havent tried for myself.
Thanks Steve! Yes, it was corroding under it. They're his winter wheels so they get exposed to salt and whatever. In the past it has had summer wheels on it. That's what I would have coated last time. It was the first time I've touched those wheels.
Thanks very much! I use IronX paste on an Incredisponge (I think that's what they're called; Corey sells them) and wash the car a second time with it. I apply a line to the surface every panel. It lasts a long time that way. It's the most economical way I have found to use IronX. If I'm dealing with a ton of fallout, I'll use the spray as well.
I asked from experience. My wife's CR-V had the same issue. I had gone thru two sets of A.R. Wheels. The second set I did just as your customer did. They are dedicated to winter wheel tire combo. The shop I bought them from steers folks away from A.R. wheels now. He's been in the business 20 plus years and is extremely disappointed with their quality control.
The first set started showing signs 2 months into ownership. They were cared as per manufacturers recommendation. Funny thing was they were installed in mid May.
Sorry for hi jacking your thread.
2 months after? That's bullshit!! It's hard to get a good wheel that doesn't cost an arm and a leg.
That Odyssey looks great, Richy!
I can't believe you did all that work in less than 20 hours.
Thanks so much Jaddie...good to hear from you man!!
