reillyryan1
Neighbors brand new truck, love this color, the picks don’t do it justice, but needed some protection, plus I got to try some new products.
Carpro Multi X - 10:1
Carpro Lift - 2 oz in foam cannon
Carpro Reset
Carpro Clay Towel
Carpro Eraser
Carpro Lite
Carpro Reload
Carpro Perl
Carpro Clarify
Carpro Inside
No polishing, just wash, clay and coat, quick interior vac and wipe down, truck was still so new it didn’t need much work. Of course it rained the very next day, as always it seems to do. Multi X and Lift made quick work initial dirt and grime, multi x worked well on rims and tires, could have gone for a stronger concentration, also used on front end and lower panels, again probably try a stronger dilution next time. Lift amazed at only two ounces, plenty of foam and a good bit left in the cannon. Reset to hand wash with a new DI wash mitt. Clay towel makes claying so much easier. Wiped down with eraser then coated and topped with reload. Perl on the tires, that was a little tricky because they were new and never had anything on them before. Carpro Lite is my new standard for protection, so easy to use and goes on about anything, no harder than a traditional wax or sealant.
Carpro Reset
Carpro Clay Towel
Carpro Eraser
Carpro Lite
Carpro Reload
Carpro Perl
Carpro Clarify
Carpro Inside
