A Non-Professional takes INTERIOR DETAILING to a professional level :)
  • Thread starter Thread starter FSportIS
F
FSportIS
I have always read a lot of topics in the forum but never post . Anyways, for my very 1st post, I'll contribute something to the community
First and foremost, I have been addicted to detailing more and more especially after owning two nice Lexus IS250 2012 and IS350 2006 and after knowing Zach (professional detailer) on ClubLexus forum. I have been researching various detailing topics, talked to various professional detailers, watch a bunch of detailing videos (both good and bad) and tested various products (some good and some bad) and techniques (some big failures and some big successes).
I finally create my own way of doing the interior. I'm not a professional detailer by any mean but with an industrial engineering background with process improvement being the focus, I like testing and come up with the best method that works for me. I don't claim this to be the best method out there but it works perfectly for me.
I use various products because I want the best of not just both world, but ALL worlds :woohoo:
Warning: This can be an overkill interior detailing but hey, I want to try to take it to the professional level and treat my car with the best I can
Products to PROTECT:
1. Carpro Cquartz Leather & Vinyl Coating.
Even though this is expensive, it claims to last the longest (up to 2 years) with UV protection. It prevents stain, soiling, oil, dye transfer, everything at the extreme level (IMO, the best out there). Yes, I tested it with permanent marker like they show on the Youtube video and it wipes off completely and easily with alcohol. I'm still watching durability claim on this one.
2. Ultima Interior Guard Plus
It gives a very clean satin look that repels dust, oil, water. It also prevents stain, soiling, dye transfer. This one claims to last 3 months with UV protection as well. It can be used on all interior surface. It transforms all surfaces into a very unique silky smooth feeling. You will be addicted to touching your car interior more literally and seriously! I'm still watching durability claim on this one :)
3. 303 Aerospace Protectant
This product, IMO, offers the best UV protection (SPF 40 :thumbup. It also gives the best natural just-detailed shine look. I have personally used it for 3 years+ and my interior always look BETTER than new even when my car is parked outside 24/7 exposing to hot sun in CA. It lasts 4-8 weeks typically per one application. I also like its darkening effect. It looks good and also a good indicator for re-application if the shine fades away.
Products to CLEAN:
1. Ultima Interior Shampoo Gel
This product cleans very well with the power of all purpose cleaner (APC) but It is SAFE on leather and would not dry it out like APC does.
2. Meguiar's Quik Interior Detailer
This is very mild cleaner and safest to use on sensitive surfaces such as navigation screen.
3. Meguiar's All Purpose Cleaner D101 (APC)
This one is heavy duty cleaner that can remove any stubborn stain or soiling.
Tools:
Horse's Hair Upholstery Brush
It is effective yet gentle enough to agitate the leather seats.
4 Microfiber Towels
(1 damp to remove APC residue, another 1 to wipe it dry, another dry one for final buff, and extra one to apply 303 protectant)
1 extra whatever towel used to dry floormats. This is to save the 4 other towels from the most dirty floormats.
1 small bucket of clean water
2 bottle of sprayers
(solely use for APC, one with 10:1 dilution, and one with 4:1 dilution)
1 stiff nylon brush
(get it from HomeDepot)
CLEANING PROCESS:
I broke it down into several sub-processes and do them in this order based my preference.
Cleaning Floormats
1. Remove all-weather rubber floormats
2. Vacuum all the areas under the seat, the seats, and crevices of the seats.
3. Take the floormats away from car and spray APC (4:1 dilution) liberally to the floormats.
4. Agitate the floormats with the stiff brush
5. Rinse them with strong stream of water
6. Shake the floormats as pre-drying step
7. Use the whatever towel to dry the floormat and then leave them outside for complete air dry
Cleaning Leather Seats and vinyl
1. Spray Ultima Interior Shampoo Gel onto the leather seats
2. Agitate with the Horse's Hair Upholstery Brush
Note: Remember to clean the brush often in the bucket of water to keep it as clean as possible.
3. Wipe it dry with 1 dry microfiber towel
4. Repeat this for all leather and vinyl areas.
Cleaning the sensitive areas such as consoles, navigation, dash
These areas should only use mild cleaner so
1. Spray Meguiar's Quik Interior Detailer onto the surface.
2. Wipe dry with a microfiber towel.
Do NOT agitate with any brush because that will make swirls and scratches!
Cleaning all the areas under the floor (usually these are the most dirty in the interior)
1. Spray APC one section at a time. Depending on the conditions, for very dirty areas use the (4:1 dilution), and for other areas use (10:1 diolution). IME, 10:1 works fine on most areas except the tough stain.
2. Agitate with the stiff brush.
3. Use a damp microfiber to wipe it
4. Follow up with a dry towel and apply some pressure to blot dry it.
5. You might need to follow up with another dry towel.
PROTECTION PROCESS:
Leather & Vinyl surfaces protection I do it based on Carpro website instruction
1. Pour at least 10 drops or one small strip onto the suede wrapped applicator
2. Work CQuartz Leather & Vinyl into the surface including all creases, and texture
3. Gently wipe off any excess within 2-3 minutes
Tips:
When you feel the drag or resistance when you apply it, you know you need to pour some more product to the wrapped applicator.
Flip the suede towel and change it as often as you need
Overlap the sections a bit to ensure complete coverage
You should NOT need to wipe or buff off immediately because the product will be soaked into the leather slowly. Only LIGHTLY and GENTLY buff off the excess if any.
Front dash and other areas that are exposed to sun the most
Since this area is directly exposed to the sun the most, I would only use 303 protectant as it has been proven to give the best UV protection in my opinion. Also, it is very easy to detect when you need to re-apply it based on the look. If the just-detailed shine fades away, I know I should re-apply it. It lasts somewhere from 4 to 8 weeks under hot California sun.
1. I spray 303 protectant liberally onto 1 microfiber towel
2. Apply it to the front dash and ensure complete coverage
3. Wipe and buff off the excess immediately
All remaining areas
I use Ultima Interior Guard Plus. It gives better durability than 303 and better silky smooth feel. It is the simplest to apply
1. Spray 2-4 sprays onto the foam applicator that is provided
2. Simply wipe on and walk away as the product will do it magic.
Do NOT wipe or buff off immediately.
3. wait 10-15 minutes, and LIGHTLY wipe off any excess.
In my experience, I just wipe on and let it do it magic and come back the next day to wipe off any excess. It did not streak whatsoever. Make sure you apply the product evenly on all the surface.
LOVE IT!!!!!!!!!! Well done, and great consolidation of information for newbs and weekend warriors
