Anyone else having difficulty wiping off Essence?
aquarianuw
I find Essence hard to wipe off after machine polishing using a DA and a polishing pad. I have used it twice and have found it difficult to remove compared to other polishes I have used previously. Anyone else feel the same?
Sent from my iPad using Tapatalk
I understand that Essence doesn't contain any oils like many others so maybe I am spoiled that way, but Essence feels extremely dry after polishing therefore difficult to remove...
Can you give us more information please?
* What kind of machine, speed are you using?
* How many product in pad?
* Working time?
* Weather conditions?
There is a little learning curve with Essence, as with any other detailing product, but once your technique is dialed in, results are simply astounding!
* Working time?
Griots BOSS G15
3 dots on a Lake Country white polishing pad
Normal polishing until it becomes pretty much clear
60 something degrees in my garage
Hope this helps
Essence
For fine finishing, try either not priming the pads, or very lightly priming when using CarPro Essence.
Essence is quite unique, and differs from other polishes you may be used to .
For Essence:
- Either do not prime your pad, or prime it very lightly.
- Use 2 small dots of product (perhaps 3-4 small dots on first pass with clean pad)
- Spread product quickly onto working area at machine speed 1
- Begin your first pass at a moderate speed (say around 4 on BOSS) with medium pressure
- Make 1-2 slow passes at this moderate speed with moderate pressure (ie up & down, then left to right)
- Make 1 final pass at a slower speed (2.5-3) with no pressure
- Wipe residue away (there should be very little since so little product was used to begin with)
- Clean pad & repeat on next section
If you use too much product, or work it too long it may be a bit difficult to remove, or you may see slight marring. The abrasives break down very quickly (just a couple passes), and you need very little product.
Once you get the hang of it, the process is very quick and easy!
Essence on a Scholl Concepts Neo Honey Spider, Megs MF, or a CarPro gloss pad USUALLY works very well!
Some light marring with Essence is possible on the very first section. When this happens try adding a few more drops of polish and hit the area again. Some paints are more susceptible to marring with a dry pad.
If you're using a microfiber pad cutting pad, you're probably looking to maximize cut. In this instance, prime the MF pad with Essence, and use 2 small dots of product for each working section.
Again, clean the pad after each section.
Essence has been only a breeze for me. DARK HORSE gave all the appropriate information.
Personally, I've been using it often with the Gloss pads, and although it's gummed up at times, I've had nothing but success in all areas of polishing and removal
Sent from my SM-G930W8 using Tapatalk
Thanks guys. Yesterday I used Essence once again on the hood of my other car in white, and it wiped off very easily. I believe last time I was working on a piano black plastic and it perhaps heated up too fast therefore it became difficult to wipe.
