Hello everyone and sorry if these questions are already answered, I spend some time searching but could find the specific answers for these
I am preparing to apply UK 3.0 coating (plan to do 2 coats) and then 1 coat of Gliss. Questions are:
Unfortunately I do not have access to CarPro Eraser, thus the substitution for an IPA cleaner which is 50/50 Isopropyl alcohol and bi-destiled water. Nor to Reload at this time.
Thank you in advance to all who took the time to guide me on this journey and forgive my english
- How long should I wait after finished the 1st coat of UK 3.0 and start with the 2nd coat?
- It might worth mention that I do not have Essence, so after final polish and full wash I will IPA clean before apply the first coat.
- Before starting the 2nd coat, should I clean with IPA solution again? or just a microfiber towel to remove any dust?
- How long should I wait before applying Gliss coat and should I also just wipe the car or use IPA before Gliss?
- Should I worry about product drying on the application suede while i wipe off, or do i change the suede often or it will last a full coat?
- After applying the final Gliss coat I will leave the car in the garage for 24hrs, is that enough? i am worried as inside my garage it will still collect some dust due the fact its not 100% sealed, is it better to cover the car or it will be fine to just wash with water after 24-36hrs?
- I have heard that the microfiber towels used to wipe-off UK will render useless as the product dry on them, will the same happen with the one used to wipe-off Gliss? just wanted to see how many mf towels will need to throw away
