CarPro and Dr. Colorchip Questions
DapperDon
So I did a visual inspection on my Panamera and have found some chips on the hood that I plan on using Dr. Colorchip on. Should I apply the Colorchip before I polish or after? And how long should I wait before a coating of CQuartz?
If you apply Dr. Colorchip prior to polishing, there is a very good chance polishing over it will pull the paint from the repaired areas. Typically I do this:
1. Polish the affected area first.
2. Carefully do any necessary paint touch-ups.
3. Finish polishing the rest of the vehicle.
4. If "need be" I do any needed polishing touch-ups in the area where I did chip repair. (If I did a good job and was careful while doing the repairs, there is no need for this step). If the need does exist, I going very lightly and be VERY careful not to pull the paint from the repairs.
5.You can coat the next day. (I like to wait a bit longer if possible, but I've done the next day without issue).
I will finally be able to get started on this tomorrow. Thanks for the tips. Looks like I will be taking my car to CarPro Town tomorrow! Next stop, Shineyville!
