Plastic
Engine
Rubber
Leather
Tires, interiors, trim, or engine bays, where are you guys using it most?
Engine
Rubber
Leather
Tires all the way! DLux on trim. But I have PERL diluted 1:1 w/ distilled water in a small 2oz plane-safe spray bottle. The spray makes it easier to apply evenly over the tire. And much faster.
How is the sheen for the interior? How long does it usually last? What do you dilute it to for interior?Engine bay and interior...
How is the sheen for the interior? How long does it usually last? What do you dilute it to for interior?![]()
Ok cool. Good point about diluting it more if needed.I use a 1:2 ratio for the interior, has a slight sheen but I use sparingly - applied once every 3 weeks. If its too shiny, you can always dilute it some more. I only use distilled water, don't trust the tap!
I wonder if PERL have UV protectants in it?...
Proven?Yes it does![]()
Proven?haha ok cool, I need to give it a try. I'm just afraid it will be too shiny and I won't be able to get rid of the sheen. That's why I haven't put much of anything on my interior so far.
Even at 5:1 there has to be benefits to using PERL rather than running around with a naked interior. At least that makes sense to me. You're right, Corey probably knows.I personally like the slight sheen, try a 1:5 ratio. I have to correct myself, i know Perl offers UV protection but as to your question of UV protectants in it, that I don't know. I'm sure Corey can answer that for us...
