fdresq4
Howdy All,
Ok, I will save you the entire process of deconing, polishing, and protecting of my truck. Instead, I will just go right to the review of the NEW AND IMPROVED RELOAD v. 2015!
As we all remember, v. 2014 had issues and was a bit of a pain to use, if not downright, well we all know! However RELOAD has been fixed and is so easy to apply and remove.
Here is the link to the product ordered from Corey...
http://www.carpro-us.com/exterior-surface-protection/carpro-reload-500ml-v-2015/
The directions on application...
CarPro USA Directions:
Shake well and avoid use in direct sun or on hot panels
Spray only the amount needed for one section
Immediately spread the product out with a short nap Microfiber Towel and immediately buff in and off.
Next, use a separate towel (I prefer the Crazy Pile towel) as your final wipe towel. Buff the area once more to be sure no streak remains
Move to next section and repeat.
How do I know it's the 2015 version you ask?? 1. I ordered it from Corey 2. Here is the proof on the bottom of the bottle...
Next, I secured two clean M/F towels, the RELOAD, and my gloves. Also, I had lighting set up. Then I sprayed the product on a section of the hood as directed on the bottles instructions...
Then I used one M/F towel to gently spread the product over the hood...
Following up with a second M/F towel to remove and buff the remaining product...
Finally, used the lighting to look for any streaks, smears, and the like...
The end result!
As compared to v. 2014, night and day difference! This product, as in this case, was used to top CQUK but I have also used it as a stand alone on our CR-V. This version says up to 6 months of protection but as of now have only had it applied for a little over a month.
I can offer this, on a recent trip from N.J. to Alabama and back, my truck looked like a bug graveyard. All I needed to do was fill my foam cannon with RESET (4 ounces), some APC (2 ounces), warm water and apply. The bugs came off with just the pressure washer stream alone...NO SCRUBBING!
I am very happy with RELOAD v. 2015. Be sure to follow the instructions on the bottle and you should have no issues.
AS ALWAYS be sure to use proper precautions gloves, eye protection, and such. Gloves will help in the proper application and bonding of RELOAD to your paint so that no foreign oils and matter from your hands will interfere. Plus we are exposed to enough stuff so gloves will aid in your well being so you don't absorb it into your body.
CarPro USA Tips:
Paint should be completely clean and free of oil, solvents, or wax before applying Reload (For Durability)
As with any product, when pressing the trigger one quick press will allow it to disperse in a finer mist.
Thanks to Corey and Avi for fixing the formula.
The end result!
CarPro USA Tips:
