CarPro Spotless Water Spot Remover - Safe ???
  • Thread starter Thread starter morjo02
M
morjo02
is CarPro Spotless Water Spot Remover safe on XPEL Paint Protection Film ?? Will there be any discoloring or yellowing using this product?
Yes it is safe, no problem if used correctly. Just follow these directions and precautions. ..https://www.carpro-us.com/paint-decontamination/carpro-spotless-water-spot-remover-1-liter-32-oz/ No it does not yellow the film.
Directions:
Shake well.
Spray on microfiber towel, sponge, or CarPro applicator/Suede
Work in the solution over the surface.
Wipe off with MF, and remove residue with Ultima Waterless Wash or rinse well with water.
Repeat steps 2-4 if necessary.
Precautions:
Do NOT use in sun
Do NOT use on hot surface
NEVER spray directly on glass. Use with caution, buff in and off instantly and neutralize.
※ Acidic solution - wear disposable gloves while working to avoid possible skin irritation.
※ Test in an inconspicuous place of any new material before using elsewhere
※ Do Not Ingest
※ Keep out of reach of children
Do not spray in eyes - Wear eye protection to be safe
May affect windscreen/window coatings and traditional sealants and waxes
After you use Spotless to remove some spots, should I go over the area with Ech20 at QD strength, and follow with Reload?
The last time I used spotless, I rinsed off the areas with water. A rinseless/waterless wash would be ok so maybe mix ech20 as a waterless wash. I would definitely follow up with some sort of protection.
I used the water spot remover on my headlights and tail lights last week and it worked like a charm... didn’t realize I️ had to rinse it though!
