What would be the recommended thinner to clean the internals of airbrush of CQuartz and Dlux? Thanks
I ended running minerals spirits through it because that is what i believe Corey once said the delivery suspension was. Then a little IP solution to remove the oils! Seems good so far.
Merlin do you level the dlux on the rims after applying?
