Thanks for all your input guys.. So I await my package of goodies I purchased.
I'm a bit confused on how i should do the first wash( what products to use first, dilution, etc... here is all the stuff I got. Anybody want to give me a step by step on how to proceed?
Iron X (1Liter)1
Merino Wool Wash Mitt1
PERL-50PERL: Plastic, Engine, Rubber, Leather (50ml)1
Iron X Snow Soap (1 Liter)1
Spray Bottle w/ Trigger (4 oz.)1
CarPro Reload 500ml (V. 2015)1
Microfiber Madness Dry Me Crazy Jr. (16" x 16")1
Microfiber Madness Summit 800 (16" x 16")2
Spotless: Water Spot & Mineral Remover 50ml1
FlyBy30 Windshield and Glass Coating FULL KIT - 20ml1
I Also have a water cannon and leaf blower to expedite drying.
Thanks!
Dionisio944~
Congrats on having your car perfected and Finest applied!
I would highly recommend Reset as your maintenance soap of choice.
The most important thing for your Finest coated vehicle is to simply wash it regularly.
So go first wash it's simply Reset, merino mitt, dry me crazy.
When washing its critical to rinse your mitt after every panel BEFORE placing the mitt back in your soap and back on the paint.
Iron X and Reload should be used every 3-12 months depending on the environment .
Reload application is as follows
#1. use on clean surface
#2. Use only in great ambient lighting (Daylight but not direct sun)
#3. Only work with one panel at a time until it looks great from all angles.
You apply as follows -
Shake well
Spray a 4-5 sprays directly onto a microfiber towel and spread out left and right and then up and down over a 2 to 2.5 sq ft area
Work it into the paint evenly until almost but not completely gone.
Switch to a fresh clean towel for final buff and remove completely whats left
Should be zero dark streaks at this point but COULD be some oily holograms in certain direct lighting.
If you have any oily holograms a water damp mf after each panel should easily remove that.
NOTE: Apply to one small panel and check in various lighting to be sure you understand proper application and that you are producing the results you want before applying to the remainder of the car.
