D
deviousdetailing
Can the leather coating be used on a vinyl convertible top?
Thanks. My only concern is the texture and consumption of product. I probably will attempt it. Will try to document it well and post my results.
Sent from my RM-927_nam_vzw_100 using Tapatalk
That's awesome! From my experience a 30ml bottle covered 2 bucket seats, 1 bench, center console and door inserts of a F150 with little product to spare. I am sure you have a solid 3 layers on your vinyl top. Texture concerns = NONE! Even on perforated seats I did not see a consumption spike.
Directions:
- Thoroughly clean all dirt, moisture, and oils from surface with non-oily, interior safe cleaner - (Recommended Ultima Interior Shampoo Gel)
- Wipe with a water damp towel to remove residue from your cleaner if needed
- Pour at least 10 drops or one small strip onto the suede wrapped applicator
- Work CQuartz Leather & Vinyl into the surface including all creases, and texture
- Gently wipe off any excess within 2-3 minutes
- May layer after 30 minutes from start of the first application
- Touch dry after 10 min / Avoid water for 4 hours / Fully cured at 3 days
This is the technique I used and instructions provided, so I would assume you should follow the same to get a good layering and proper bonding between layers
Thanks for the detailed documentation and my sincere apologies for not seeing the thread sooner! U would have said proceed at your own risk as I wasn't sure how easy it would be to apply evenly on this particular material but it appears you did an excellent job! I was surprised at the lack of beading after the first coat but interested in the difference with subsequent coats. It appears the first soaked right in
The first video was before the first coat, showing how the water reacted before any treatment was done. It was surprisingly very easy to apply and was both the customer and myself were very pleased with the results.
