I'll pass this info along as well, thanks much!Looks great, good job! Be sure to give it plenty of time before getting it wet or washing it. With boats, I tell my clients to wait at least 5 days before putting it in the water, and at least 7 days before washing with soap.
I've used CQUK on my boat for 2 seasons now, with this upcoming summer being season 2. I store my boat in a heated building for the winter and do all the detailing there where it's 10 degrees Celcius. UK's temperature range allows me to do this.
Gelcoat:
Last winter I compounded the gelcoat using Sea-Shield's polishes, applied Erasor and then 2 coats of CQUK. The first coat needs to go on fairly thick as it just absorbs right in "appearing" to flash immediately. After you've filled the pores, it goes on a little more as you've seen in car videos. I did have some issues with light, not always being able to see streaks until I got it outside a few months later. I only did the superstructure the first winter.
This past winter I used Essence to prep, then topped with CQUK. I used a Rupes Bigfoot and MF cutting pad with Essence. I highly recommend this product and process. I'll say that my gelcoat is in very good condition, I'm almost fanatical about it. If yours is in worse shape, you may need a stronger compound before the Essence. I did have a few areas that needed more, and used Sea-Shield #2 Cut&Polish with a Flex rotary and a wool pad, followed by the Essence. Essence goes on quickly and does a fantastic job, I've never seen gloss on a boat like this EVER. As an added bonus, I used much, much less CQUK to coat. I did the whole hull and superstructure this year.
Plastic windows (Strataglass, vinyl, and Stamoid):
I have a hard top so no canvas roof, but I do have removable windows. I cleaned them with Ultima Waterless wash (diluted), then distilled water and finally Reload. Reload works extremely well, better than any other product I've used. It keeps water spots minimized better than anything else and keeps my white Stamoid clean. The Stamoid looks the same this winter as it did last year when I applied Reload the first time. No other product has been able to do that for me.
Stainless Steel:
I used Sea-Shield Metal Polish (similar to Flitz), then followed up with 2 coats of CQUK.
Acrylic wing doors and shower doors:
I used Essence this year and the results are almost dangerous. I've now had 2 people walk right into the closed door if that explains how clear it is.
Fly by Forte:
It didn't work last winter. The temperature wasn't warm enough for it to flash, so I used my old Sea Shield Glass Polish. I did apply FlybyForte last fall, but have no idea how well it's worked yet.
Summer / Weekly Maintenance:
I bought a small pressure washer, the ARBlue AR118, that I can keep on the boat all the time. I added a foam cannon, and use Chemical Guys Honeydew Snowfoam. I wet the boat, soap with the foam cannon and then wash with a Microfibre Madness wash mitt and rinse. I wash at least once per week, more if it's rained or during pollen season. I used only about 1/2 gallon of CG Honeydew, which suprised me because I bought 5 gallons and was not frugal with it. The foam cannon had the advantage of putting a soap that clung to the vertical surfaces long enough to wash it and rinse. Many other methods just run off quickly. As an added bonus, the lubricity is a big advantage on the sensitive vinyl. I would wet, soap, agitate,rinse each side starting with the transom, port side, bow, starboard side. Then I start drying in the same order. I use Microfiber Madness Dry Me Crazy last year and there is NOTHING better, especially on the vinyl. If there are any water spots because it got too dry before I got drying, I use diluted Ultima waterless wash or Distilled water. I prefer distilled water on the vinyl windows.
Every 8 weeks or so I used Hydro 2 between the rinse and dry stage. It added only a few minutes to the wash routine. I may have done it more often than needed but it was so easy, I decided it was better to be safe than sorry. I could see improved beading even after 2 weeks so I'm glad I did. The cost is insignificant compared to the saved time and energy. I went through about 1/2 liter of Hydro2, so really not that much considering I get 1MPG in fuel economy
The results:
Black streaks were drastically diminished, and most of them could be wiped off with a dry finger. The remaining streaks, which were rare, washed off with soap and water. Previously I'd have to go with a cleaner wax on areas, especially the transom, weekly.
My treated windows left fewer water spots than untreated windows and made cleaning them easier.
I also polished the interior of the bridge with CQUK. I have a Chesapeake Bay Retriver that loves the water but is prone to ear infections. When he gets them he shakes so hard that his ears bleed and spray micro drops of blood everywhere. They're so small you can't see them until they dry and the sun browns them. Previously these required the buffer to get out, after I can just wipe them off with Ultima WW or water.
I also used Carpro Leather coating on my bridge seating. It completely prevented any staining from my dogs oily coat that almost destroyed the seating the previous summer.
Gelcoat:
Stainless Steel:
Fly by Forte:
The results:
