R
reillyryan
So I'm giving CQUK one more try, I had previously coated a car and it only lasted about 3 months before it was rittled with water spots, contamination, etc, etc... The car was maintained about every other weekend at the most, washed with Reset, avoided using to harsh of chemicals like apc on the coating, mainly stuck with just reset, which did fairly well, and always applied Reload after the wash.. But as mentioned, the coating started to fail mostly on the flat areas like hood, roof and truck lid.. When the water spots and contamination began to appear I used spotless and Iron x to try to revive the paint (I was told these won't affect the coating, but Tar X may)but nothing could save the coat, it was gone.. So to rule out any personal error in application I'm trying it again.. I mean no other Carpro product has given me problems like this and they all have worked flawlessly, only CQUK.. I guess my questions, what are you guys seeing in durability, any comments on water spotting and contamination, and what are you guys seeing as the best methods for washing a coated vehicle, what to use, what to avoid??? Thanks
