I have a question. I am going to paint correct a car with Carpro reflect and finish with Essence, but I didn’t get any Eraser. Can I just use an IPA solution, and what dilution?
I tend to let the vehicle sit overnight to let the SiO2 in it cure and do a light prep wipe to remove any residual oils and light dust. I do it as a precaution. You may be able to find Mothers CMX Panel Wipe at your local auto parts store.
Here is info from the FAW section of the product.
2- Do I have to use Eraser between Essence and CQuartz?
If your using Essence by machine and you wait until the vehicle is finished then you can apply Reload or CQuartz after you finish the vehicle starting in the same direction you polished. If you want to be ultra safe you can still Eraser but in our testings to date we have not seen any failure when we skipped Eraser.
This might help. 6:30 into for a homemade prep solution.
