C
Clarkgriswald
Well today was the day I wanted to really clean my paint up after doing the baggy test and was totally shocked how much crap was on the paint. Went okay (ran into some issues) for my first time.
I started off by rinsing my truck (Black Ram) with water. Followed by washing with Reset. That part went fine.
I wasn't sure if I should dry after washing of just go right into Tar-x. I dried my truck fairly good, I then realized that I was going to run out drying towels. I usually just do a UWWP which didn't involve too much water.
After my truck was dry I started using Tar-x and I was doing a section at a time, spray on, agitate, and then rinse. I don't know if that was the best way to do it or not.
Water was everywhere on my truck now and I knew I didn't have enough drying towels so I just used Tar-x on the rest of the truck even though it was wet.
After the Tax-x I dried my truck again and thought this time I was just going to Iron-x the whole thing at once and then agitate and rinse. That was a pain for me because I was rushing to not leave it on to long because I didn't know what would happen if it dried.
I had the wife wash it down while I was agitating the Iron-x all over. After that rinse down I decided I was going to spray the truck down with spotless while the truck was wet. Don't know if that was a good idea or not. That dried really fast, too fast for me to do the whole truck I think.
Then I washed it again with Reset and dried it really good and then did the baggy test again. I was hoping to feel a fairly smooth paint. I was disappointed. The paint felt better but not what I was hoping for and being on a black color it was hard to see if any tar or iron was melting away.
I just got two bars of ultra fine clay to try just in case and I decided I was going to try it and see if it made a difference. It sure did! Amazing actually. I was worried to use clay because I don't own a polisher if something went wrong. I got a couple marring marks but you could only see them if you had a super bright light on them.
After claying the whole truck and wiping it down with Eraser as I was going, it was time to use Reload. This was the part I was worried about most before I started because I've read a lot of stories of how it was oily or hazy or too heavy. Maybe I didn't put enough on but it was SUPER easy to use and wipe off. I just did a couple squirts and some on my MF and wiped on and buffed off. Turned out really really nice I think.
My question is to all of you who have done this a lot more than me is, what did I do right and wrong? How would you have done it. Doing a full size truck is a lot of work.
I have some streaks/water spots/ who knows what, on my windows that I can not get off no matter what I put on it. You can't really see it until you wipe the window and then they pop. Its all over the windows. I tried more spotless and I tried eraser and neither worked. You can feel it with your fingers it almost feels like ridges. Is that form not rising the other stuff off fast enough? Is the only way to fix it by polishing it?
It was a long day, took about 9 hours for me to do the outside and inside. Anyone who thinks detailing a car is not a job that requires any skill or a learning curve is sadly mistaken IMO.
Thanks for the help and I appreciate any feedback.
Josh
Josh
