X
XAMfed
I am going to be trying to apply CQUK this weekend. I see that I am supposed to use reload about an hour after install. Is this a must do? I didn't see that part when I bought it, so I don't have it.
no, it will not. It will be in the garage for 24 hours. plus we are not supposed to have rain for at least 8 days
Great, thanks for the help
A nice polish (Reflect) makes the shine look so awesome.
Did you consider Eraser instead of plain IPA?
I would use Reflect (no fillers to affect bond) and Eraser (not worth risking a wasted effort) if all oils aren't removed the coating won't bond.
Go easy at first… Check one panel after your done and take some time to check it in other lighting (great daylight type lighting) before completing the vehicle.
#1.- Apply to the surface one section and then wipe it off before it becomes sticky.
#2 - Wiping with only the Suede towels can leave high spots. Be sure to completely wipe off the residue. It should NOT be difficult to wipe BUT you do want to go over it enough to remove residue. This requires going over it a couple times before moving to the next section or panel. Use the CarPro Boa towel as your follow towel behind suede.
#3 - High spots reveal themselves best in great ambient lighting (daylight but not direct sun)
#4. - Be sure to switch out the 4” Suedes after every other panel - 10-15 minutes of using the same suede is ok but no longer.
Thanks, will do.
It is my Wife's SUV
Plan of attack
Wash
Clay
Iron X
Wash
Polish (shouldn't need a buff, it has been protected with Sonax PNS since new)
IPA wipe down
CQUK Application
I would do Iron X first, then clay.
You will be amazed how many contaminants Iron X will remove by itself, and how easier is to clay afterwards![]()
