HOW-TO: Reload 2014V1 (New and Improved) like a Pro
Dr_Pain
I've read soooooo many threads on the 2014 V1 "New and Improved" Reload that my head is spinning. A lot of anecdotal and sometimes silly replies and some legitimate complaints. It does seem as though that I was a lot more forgiving of the hiccup Reload sustained in its development. Obviously I would have more realistic expectations having tried so many "New and Improved" products over the years, and realizing the goals CarPro had for the product. It is a lot more concentrated and does have impressive qualities (and longevity), but I will agree that it did depart from the ease of application that Reload 2013 was known for. I did an extensive review of the product, trying to consolidate the information that was out there, but we still have confusions and application questions that remain. Here is my previous thread on the subject: REVIEW: CarPro Reload 2014 "New & Improved"
If you want to start all the way at the beginning, I will direct you to the wash/prep process, which I did as a "How-To" as well HOW-TO: Wash you car like a PRO (using CarPro Reset) but if you just want to concentrate on the Reload portion, just read on! Please note that prep is the key for Reload's longevity!!
attachment.php
The subject vehicle is a 2013 Tuxedo Black Ford Raptor (my daily driver). If you've read the other "How-To", then you know I set out to be "unconventional" with this series of How-To's, and true to form, this How-To will also be unconventional. So what makes it unconventional??
  1. The truck is black and will be Reloaded FULL STRENGTH!
  2. Reload will be applied in FULL SUN!
  3. Applied Reload THICK!
After a thorough cleaning with CarPro Reset (LINK HERE!), the truck was dried and allowed to sit in the sun as I was preparing myself to apply it. I know, a BLACK truck baking in the sun!!!
PRODUCTS USED
  1. Reload 2014V1 LINK HERE!
  2. CarPro Boa MF towel LINK HERE!
  3. Microfiber Madness Summit 800 LINK HERE!
  4. Skyline Waffle Weave Drying Towel LINK HERE!
One of the biggest complaints about the product was that it would leave some oily holograms. This is not to be confused with people leaving high spots. High spots are due to operator error whereas the oily holograms are due to left over carriers which were hard to completely remove from the paintwork. One of the remedy was to dilute the product, which from what I understand would decrease the "qualities" of the product, so I fundamentally REFUSED to do that (even though it is recommended on dark vehicles). So how does a Pro do it? I can tell you that this Pro got it done through experimentation. I ended up trying 4 different brands of microfiber towels and 3 different naps. I've experimented on all the proposed method and finally found one that was the absolute "end all" (at least for me). Here is, in a picture form, how it worked for me (remember this is FULL strength and in FULL sun!!)
attachment.php
Reload was applied THICK!, as you can see below. It was spread evently with the CarPro Boa and leveled properly to prevent any high spots (which are seen as darkened areas)
attachment.php
What do those "hologram" look like?? It was easy to see them but hard to capture on camera, except if I made the camera out of focus. These are examples of those oily residue
attachment.php
attachment.php
attachment.php
I did try several different MF (wet and dry), and different techniques to remove the oily residue, before settling on the easiest (for me, in FULL sun). I found that using a moderatly damp high quality waffle weave using a slow light touch would remove the residue and followed with the Summit 800 to buff. Did it work?
attachment.php
attachment.php
attachment.php
I also found that using a high intensity light would also show those darn oily streaks, so here is a before and after!
attachment.php
attachment.php
So what kind of "glamor shots" can I share to convince you to use the product??
attachment.php
attachment.php
I know some of you questioned me using it on my matte black vinyl but....
attachment.php
Need more convincing?? How about some bead shots??
attachment.php
attachment.php
attachment.php
attachment.php
Now that is one happy truck!!
attachment.php
Thanks for reading. As usual, I welcome comment, questions and suggestions!
Very nicely done Doc Claude! Gorgeous pics and enjoyable writeup as well! :):) Adaptation is the key to success with so many things!
Nice, Claude!
Just to be clear... You sprayed reload onto the paint, spread with the boa, then immediately wiped with the damp ww, then buffed with the dry summit?
Sounds like a fair amount of towel juggling, but I'm willing to try anything to remove these carrier halos. I have reload down to 3:1 (water to product) and am still getting them. I like to use reload as a quick detailer quite often, so durability is never a concern of mine for my DD, I just love the added slickness and gloss!
Thanks for the write up... Enjoyable as always!
Nice, Claude!
You got it Zach!! A slow hand like removing a high grade carnauba wax, just to let the micro "pick up" the carriers
Nice to finally see some pictures of the much discussed "oily holograms". After seeing those, I now believe that the streaks I have in one small area after applying Reload are high spots rather than holograms. I guess I just missed buffing off that spot properly.
One of my intent in producing this was to show that Reload is not as bad as people are making it to be.
I purposefully broke all the rules.
  1. I applied in full mid day sun
  2. I applied on a hot panel (of a black truck mind you)
  3. I applied on black color full strength
I am sure glad you benefited in seeing those oily holograms. I hope others get to see it as well to be able to differentiate. The remedy to your issue is simple: Reflect on a MF applicator by hand on the problem spot. This should solve your issue quick!
I really appreciate your taking the time to do this demonstration. It definitely cleared up my misunderstanding regarding the streaks that I had (just in one small area) after applying Reload over CQuartz UK. I don't have any Reflect on hand as I'm still using up some P21S Paintwork Cleaner before I order the Reflect. It should work just as well - right?
In any case, I'm very satisfied with the results of the CarPro products. The beading is amazing.
This is some good info. I am getting that oily holograms after applying my Cquartz. I was using the sued 16x16 micro towls to wipe off and just couldn't figure out why I am getting this. But I was able to get what it looks like in direct sun. But when not in direct sun it looks great.
Many of us have found that using a medium nap microfiber (like the Boa) instead of the microsuede will help to remove these carrier halos when using CQ or CQUK.
Thanks. So you think I will need to compound the panels again and reapply and use a medium nap micro? Or Wash and try buffing with the Boa again?
Do you know that its the UK or could it be the Reload you applied later? Do they move when you wipe with a towel? I suspect its possible you waited too long to buff off when removing. Was it sticky when buffing?
If its Reload you can wipe them away with a wet MF towel.
If they are set and part of the hard coat and not oil on the surface then washing won't remove them BUT you do not need to compound. At the VERY worst you can very lightly literally one pass with a soft pad and Reflect to polish away the holograms. Then apply another layer of UK to end up even thicker than before.
Fist, whatever you do play on only one section and check to verify results before repeating on the entire car.
I haven't done reload and it is just Cquartz original I applied. I am waiting for reload to be delivered. I also buffed cquartz about 3-5 mins after applying. I was able to see it move when I wipe. But need to check again as it could have hardened now. Thanks for the info I will try that.
