Hydro2 dilution ratio
aquarianuw
On the bottle it says 1:3, which mathematically, means for every 1 Hydro, there is 3 water. In other words, for a total of 4 combined, there is 1 Hydro2 and 3 water.
However, on the CarPro website, it mentions: " For every ounce of HydrO2 you make 4 oz ready to use spray. Dilution of 1 part Hydro to 4 parts water (20% HydrO2 + 80% water) "
Which one is correct? 20% Hydro + 80% water is NOT 1:3
Sent from my iPad using Tapatalk
3oz of water and 1oz of Hydro2. That's where you get the 4oz of ready to use spray. Just use the 3:1 ratio and you will be good.
Thanks. So a 500ml bottle of hydro2 makes 2 liters of the spray, which is still more expensive than 2 liters of Hydro Lite. Am I assuming correctly?
I need to fix that, my apologies.
I would dilute at least 1:4
Here's some more tips
Hydro2 Tips:
Rule #1 wash the car
If it has wax or sealant use a soap that will kill that a bit. (Iron x and claying if needed)
Rule #2 rinse well and apply a fine mist of Hydro2 (diluted with at least 4 parts water) to the wet / cool surface
- RINSE after that section which will be about 30 seconds at most from when you started (this basically means you break the car into 5-6 sections at a minimum.
NOTE: Rinse means you rinse everywhere the product did or may have landed or floated in the air or dripped onto.
Move to next section
That's it
For instance if your spraying the passenger side and you see the wind is blowing away from you just go ahead and assume you will be rinsing all the horizontal surfaces to avoid tiny overspray dots.
So, you sprayed the passenger side, it's 20-35 seconds later or sooner if your really fast, you pick up the hose and turn it on. FIRST thing you do is spray off the roof and horizontals really fast to dilute any mist up there (takes 5 seconds to dilute it) and then get to the side you intended on. If you think your moving too slow then run a mist of water across the whole side and then rinse more thoroughly immediately after.
If your slow then break the car into 8 sections or even more if you want to be safe.
Glass: if the car was baking in the sun and the interior was 180F consider the fact the glass may be warm and you need to cool each panel a bit with running water before a fine mist of Hydro2 etc
Dry car with Microfiber Madness WaveRider towel
