yg1829
I figured I would try something yesterday that I have been pondering for a while...hydro2 lite in a rinsless wash!!
First let me say I'm sorry for not having any pics. I was really rushed for time yesterday. I will be experimenting more with this and will have some pics next time.
I'm not sure if anyone has tried this yet as I haven't found any threads discussing it but here goes....
Wash process -
Rinsless wash using UWW+
Diluted as recommended @ 1oz to 3 gallons
1 bucket with grit guard and 6 plush microfibers
Two waffle weave drying towels
1 bottle of hydro2 lite used as a pre spray.
Ok so let me start by saying my truck came out of the body shop a month ago with some nice new holograms[emoji35]. Unfortunately I won't have time to correct, polish, and coat until next spring so my truck made the perfect candidate to try this on. It was a little to dirty for a rinsless wash. I usually pretreat my panels with a dilution in a pump sprayer. If it's bad enough I will head to the coin op and pressure wash first. (No access to a hose right now)
Disclaimer - DO NOT USE HYDRO2 LITE AS A PANEL PRETREATMENT ON A DIRTY PANEL AND DO NOT LEAVE TO DRY. ALSO DO NOT TRY THIS TECHNIQUE IN THE SUN OR ON A WINDY DAY.
I wanted to get a little protection on my truck so I thought of this and figured why not. I started on the roof as I always do. I sprayed a quarter of the roof with H2lite and grabbed my microfiber soaked in UWW+. I rang it out a little and began to wash that quarter. I then grabbed a WW drying towel and dryed the panel. Then I took a second towel and did a final wipe. I noticed a very clean, glossy, slick surface with no streakes or blotches so I continued and finished washing the entire truck this way and it came out great!!
I've used H2lite as a wowo application before and it's pretty tricky. If your not quick it dries streaky and blotchy.
I always wash a bigger section than I dry to prevent my drying towel from dragging In dirt.
What I noticed with this technique is where the H2lite and UWW+ dried on the paint it left these same marks but when you wash and dry the next section it cleaned right up [emoji16]
I know the durability will be less doing this but I just wanted to see if it would work and I believe it did. The paint felt slicker than it does with just UWW+ and I think it looked glossier.
I definitely didn't like doing this outside because of the overspray on clean panels but maybe I could just spray the wet microfiber instead of the panel??
Then I got thinking what if I added some hydro2 (not lite) right to my rinsless wash solution? Hmmmm.
Even better maybe carpro could make an sio2 infused rinsless wash!!! That would be cool!!
I'm looking for some feedback so tell me what you think. Is it worth it? Is it just a waste of product?
Sorry I'm not the best at expressing my thoughts on a forum. Hope this wasn't to hard to read. Thanks!!
Sent from my SM-G920V using Tapatalk
Wash process -
