M
mobiledynamics
New at Hydro2
If one is mixing up enough, aka, nothing leftover in spray bottle post application, is Tap Water fine or is distilled still preferred for this application.
1 Garage Queen and 1 DD had Finest
The beater has Reload
What is the effect of Hydro2 relative to dilution rate ?
If one is spraying it already on a wet panel and then ~hosing/blasting~ it off, how much of the dilution ration does play into this.
For the beater, I'll use the recommended 1:4
For the Finest, as a topper, 1:6 or 1:8
Going back to the analogy of wet panel, water rinse activate/blast off, doesn't the product even when mixed at 1:4 get diluted pretty quick to XYZ water to product ratio.
Lastly, do ya'll go ball2walls and spray everything including windows ?
Last thing I would want is to have Hydro2 cause streaking/etc on the windshield and I would hate it and end up needing to polish it off
