HYDRO2 Shelf Life Question
  • Thread starter Thread starter pimpinjedistyle
P
pimpinjedistyle
"It is recommended that you only mix enough solution to use within a short period of time, so do not mix the entire bottle of concentrate if you do not intend on using it right away. Simply mix a small amount before each job, and store the remaining concentrate indoors to help prolong the shelf life." (Article from detailed image)
So what is the shelf life after you create the dilution of Hydro2 and water?
wonder about this also, about 8oz worth of solution mixed from 6 months ago. should i dump it? or could i use it on maybe wheels?
I would still use it Don.
Op, if it's mixed with pure water then it will last years. If mixed with tap or has minerals then it depends. Maybe 30 day max is best but probably still work after just not as strong
Thanks for the reply Corey!
