Thank you much! The tires are wearing Tuf Shine clear coat
No problem! Thanks for the info, I like the sheen. Fantastic job. Any issues on applying UK?Thank you much! The tires are wearing Tuf Shine clear coat
How was layering it? Easy?So far I've got no problems with it. It was a hassle to get it uniform but I remedied that by putting on 3 coats (let each dry before applying the next). Gotta be careful to wipe off any residue from the wheels as it won't come off easy if it dries
How many layers did you do of UK?I had a couple of high spots but I just polished by hand, used eraser and reapplied. No problems at all. It rained last night, came out this morning expecting to see water spots and I couldn't find one
I did 2 coats, 2nd coat was no problem aside from the massive heat I was working with. It's best to inspect the paint from several angles to make sure you've buffed it all off.
