CQuartz Leather & Vinyl Coating is the ultimate in protection for both leather and vinyl surfaces throughout your vehicle! Our new high tech formula was created using only the highest quality ingredients available and offers a beautiful “better than new” finish with no added gloss! It was designed to provide an excellent combination of soft to the touch tactile feel, extreme protection, and unbelievable durability. CQuartz Leather & Vinyl was specifically developed to resist stains, dirt, jean dye transfer, and UV rays for years to come. Maintenance of your interior surfaces becomes as simple as wiping with a damp towel and walking away!
CQuartz Leather & Vinyl has been tested against a variety of chemicals and conditions including mud, grease, dye transfer, crayons, and even super glue and is proven to resist stains better than any traditional leather product. CQuartz Leather & Vinyl does NOT fade or yellow in extreme UV and protects the existing materials with UV inhibitors integrated into the formula to provide the ultimate in UV protection as well. Protect your interior to the same degree you protect your paint with CQuartz Leather & Vinyl coating!
Features and Specifications:
• Durability: 1 to 2 years
• Resists dye transfer
• Hydrophobic & Oil Phobic
• Stain resistant
• Chemical resistant
• UV resistant
• "Easy clean" affect
• Preserves color and resists fading
Materials:
• Finished Leather
• Vinyl
• Synthetic leather
• Interior plastic and Wood
Consumption:
5ml = 1m2
Directions:
1. Thoroughly clean all dirt, moisture, and oils from surface with non-oily, interior safe cleaner - (Recommended Ultima Interior Shampoo Gel)
2. Wipe with a water damp towel to remove residue from your cleaner if needed
3. Pour at least 10 drops or one small strip onto the suede wrapped applicator
4. Work CQuartz Leather & Vinyl into the surface including all creases, and texture
5. Gently wipe off any excess within 2-3 minutes
6. May layer after 30 minutes from start of the first application
7. Touch dry after 10 min / Avoid water for 4 hours / Fully cured at 3 days
• Stain resistant
• UV resistant
Materials:
• Finished Leather
• Vinyl
• Synthetic leather
Consumption:
5ml = 1m2
Directions:
