Mar 6, 2020 #1 F fawad New member Is ceramic coating safe on plasti dip? If yes then which is better choice. Dlux or UK? If no then can I use Perl?
Mar 6, 2020 #2 The Guz Member You could try using DLUX or CQUK in a spot. Plastidip is rubber so Perl should work just fine.
Mar 8, 2020 #3 Merlin I love shiny things I have never used CQuartz ceramic coating on plastidip. That said..it may work...I use it on PPF. Try a test spot. Let us know your results.
