Astatenate
Just coated my car CQ UK 2-3 weeks ago. Did the full process. Washed car. Full chemical decontamination. Clay bar to further clean any contaminents. Polished any scracthes. Wash x2 to remove polishing oils. Wiped entire car down with a 70/30 mix IPA. Wiped down a final time. All in about 55-60 degree weather inside a garage so ambient air temp was probably around 60-65 the entire time.
I put down 1 coat let sit for 60 secs and buffed off. Waited maybe 30 mins. Put 2nd coat on. Wiped off almost immediately. Let the car sit for 24 hours. Applied reload spray on all panels gently wiping on and buffing off with MF towel. As it sat there, another 2-3 days as it was sitting waiting for wheels it cured at temps between 45-65 degrees. I put wheels on. And drove the car nearly a week after applying 2 coats of UK! I wanted to test my new ceramic coating. So I let I grabbed a small glass of water and dropped it on there, it beaded up like crazy and rolled right off my hood. The next day it rained, again, water was beading off like crazy. Well I went out of town for a week this past week for work. Came back (it rained all week) and it was beaded up on my car. So I drove it around on interstate (about 70-80mph) and the water rolled off the body like beaded off pretty well.
Also side note: I added RELOAD ONLY to windows, windshield & rear glass.
Well today I decided to wash it (even though its 40-45 degrees) as there's no chancce of rain for 3-4 days and I washed it with a non wax / non gloss enhancer added basic Meguiars wash. First thing I noticed the beading wasn't nearly as good when I sprayed it off with power washer, also the windshield where the reload only (no cermaic coating) was sheeted off like there was nothing on there? But when I started driving it rolled right off with no use of windshield wiper?!?!?!? So all my glass that had been coated with reload is sheeting off like there's nothing on there but there is. Im tempted to just wax my glass like I have done in the past (barely have to use windshield wipers) the other thing I noticed was that the beading on my paint where UK and reload was applied was not nearly as good as 2-3 weeks ago?!?! What gives? Also when I went to dry car off I used an absorber towel as I always have and the water just smeared across the paint. Wouldn't never actually dry.
Am I missing something here? I thought Ceramic coated vehicles especially with reload on top as a booster should bead water like crazy, on my paint and reload on glass should bead like crazy not sheet off. Also, drying should be a breeze? But it wasn't IDK if it's the cold weather? Maybe it's too humid outside? Idk. Im 100% sure every square inch of the paint is ceramic coated and has reload as an additional booster, as I'm very OCD and made sure of it. And all glass was coated with RELOAD. Now my glass barely beads water it sheets off unless I get to moving fast then it starts beading off. Confused... And the paint is still beading off but not nearly as aquaphobic as it was when first coated. Also drying was a PIA!!! Was just smearing over and never really actually dried. I gave up and decided to just let it air dry and wipe it off with reload and MF in the morning. Kinda upset and just hoping its the cold maybe humid weather? My inside glass was fogging up pretty bad so I'm assuming its pretty humid. And I know since it's a glass like coating it's gonna have the same properties of glass and my glass was doing the same streaking as I was trying to dry...
