T
TXFIVEO
Detailed my MB this weekend to prepare it for the upcoming North Texas Winter. Started off with an Iron X Snow Soap foam with Optimum Power Clean in my CarPro Foam Canon as a "pre-wash." Then washed the car using the Iron X Snow Foam using the direct to chenille wash mitt technique. I like his method, makes quick work not having to use any buckets (just rinse mitt after each panel).
After the wash I decon'd using Iron X. The Iron X was allowed to dwell and then it was "rubbed in" using a sponge. After rinsing, the car was "clayed" using my Speedy Prep towel (fine grade).
The car was then dried and prepped for polishing. After several test spots only a mild polish was needed. For the paint an orange Buff and Shine pad and HD Polish left a fantastic result. The XPEL PFF areas were polished with Optimum Hyper Polish using a white Buff and Shine pad. After polishing the vehicle was wiped down with CarPro Eraser to prep the paint for a coating.
The wheels were removed, washed with Iron X Snow Soap, clayed, and polished with HD Polish (face and barrels). They were wiped down 2X with CarPro Eraser and coated. They were reinstalled and torqued to the proper 96 foot-pounds.
Optimum Gloss Coat was applied (two thick costs) and the car was pulled outside in the sun to assist with curing. I was impressed with Gloss Coat. Very simple to use and the initial gloss was nice. Much easier to apply than CQUARTZ UK. We'll see how it holds up compared to UK which is on my other vehicle.
Products used:
CarPro Iron X Snow Soap (great decon soap)
CarPro Iron X (Decon)
Speedy Prep Towel ("clay")
ONR at Clay Lube dilution
Optimum Power Clean (tires)
HD Polish
Buff and Shine pads (Orange/White)
Rupes 21
CarPro Deluxe (plastic trim/headlights)
CarPro PERL (tire dressing)
Optimum Gloss Coat (paint & wheels)
I didn't have time for before pics, and it was overcast for my afters, but here we go:
Products used:
HD Polish
Rupes 21
