Well... In about 9 hours it will be!
Introducing the Microfiber Madness Incredibrush!
Imagine a wheel brush that is as soft as the wash mitt you use on your paint... Imagine the stem is made of high-grade stainless steel and not the typical cheap materials brushes have been made of in the past... Imagine it has a handle that is as functional and ergonomic as a quality power tool.... Imagine being able to easily remove the "Incredi-cover" and machine wash it or replace it... Imagine a core made of special foam designed to absorb enough water to safely clean each wheel.... Now open your eyes because it is here!!
Since the sneak peak at SEMA 2014 we have been counting the days until its completion! After 2 years of development Microfiber Madness proudly introduces the Microfiber Madness Incredibrush!!
The Microfiber Madness Incredibrush is the answer to every enthusiasts dreams! It features a rustproof stainless steel stem dressed with a nylon coating to protect from any possibility of scratching your finish. Additionally a foam core was developed with high water absorption so you have plenty of water dispersion while cleaning your wheels. The industrial strength molded plastic handle is designed to provide a firm grasp and never slip even when wet!
And finally the icing on the cake... the Incredicover! The Incredicover is easily removable with a hidden Velcro seam, which pops open if you would like to remove and machine wash, or replace! The Incredicover is extremely durable and will last but should it ever need replaced or should you prefer to have one cover per vehicle this is an excellent feature!
The Microfiber Madness Incredibrush takes its name from the unique design of the "Incredi" fabric by Microfiber Madness. The Incredi fabric merges the best of both microfiber and merino wool theories. Utilizing the well know cleansing abilities of microfiber, Madness created a special fiber blend enabling a thick "pile" to be created similar to those typically found in premium quality wool wash mitts. One characteristic however is unlike both wool and traditional microfiber... Unique to Incredifabric is the trait of being easily rinsed free of dirt! The custom blended fibers are designed to remove dirt particles from your paintwork and then rinse clean very easily, minimizing the chances of swirls.
Find out more and pick up your IncrediBrush here!
