Mini-Review: RYOBI High Flow Automotive Pressure Washer
Mini-Review RYOBI High Flow Automotive Pressure Washer
Home Depot Pressure Washer 1.8 GPM Model # 1013019632
Pressure Washer Model comparisons.
Ryobi website info Info:
"Ideal For Cars, Trucks, & Other Vehicles
Premium Car Detailing Accessories Included
1.8 GPM High Flow Rate for Optimized Cleaning
The RYOBI 1.8 GPM Automotive High Flow Pressure Washer is ideal for automotive professionals and car enthusiasts.
With a design that prioritizes an increased water flow of 1.8 GPM, this high-performance pressure washer achieves a deeper more effective clean than other models.
The shortened design of the stubby trigger handle provides less vibration than a standard trigger handle, creating a comfortable one-handed experience while also allowing you to stand closer to your vehicle.
The specialized automotive nozzles can attach directly to the trigger handle and feature a dome design and protective overmold enhancing durability and precision.
The 15° nozzle offers a concentrated spray for tough stains, the 25° for general cleaning, and the 40° for a gentle rinse.
The included foamer delivers thick soap to clean dirt and grime effectively. The included 40’ hose is 2X longer than a standard hose, making it easier to reach around your vehicle without constantly moving the pressure washer."
My thoughts.
If you're looking for an inexpensive pressure washer designed for washing cars. This one makes great foam!
The main requirement for making a thick foam is GPM not PSI. To get good foam you should have +/- 2.0 GPM.
However, when I've been looking at PW's with 2.0 GPM they are usually around 4000 PSI or greater!
That'll peal your paint and your wallet! IMHO for the price point the Ryobi model 1013019632 it works great!
This unit is small (about the size of a loaf of bread), It's electric (lower maintenance), and it easily fits on my shelf.
I used the MTM Hydro PF22.2 Professional Snow Foam Cannon with the Ryobi 1.8 PW
I recommend quick disconnects for both hoses.
I purchased the M MINGLE Ultimate Pressure Washer Adapter set (Amazon $20)
This covers the garden hose in/out and hose-to-gun in/out.
I believe it even has a swivel for the bottom of the PW gun.
I'm happy with the results of the Pressure Washer and the quick disconnects.
If you have any queastions please reply to this post.
The older Ryobi model was $99 +/- 1600 or 1800 PSI and 1.2 GPM
20 foot metal hose and did not have a short handle gun.
The new Automotive model Model # 1013019632 is $149 and includes...
  • 40' rubber high-pressure hose to easily reach around vehicles
  • 1.8 GPM 1200 PSI
  • 3-year manufacturer's warranty
  • Includes: 1.8 GPM Automotive High Flow Pressure Washer, Stubby Trigger Handle, Metal Spray Wand, 40' Non-Marring High-Pressure Hose, ¼" Quick Connect Nozzles (15°, 25°, and 40°), Foamer (foam cannon), and Operator's Manual
In short
The GPM is higher for thicker foam
The PSI is lower for better safety
The hose reaches around the vehicle
The gun is a short version (not the BEST but it's not bad)
It comes with a foamer cannon (which I think is not very good)
I used it with the MTM Hydro PF22.2 Professional Snow Foam Cannon with good results
Please let me know your thoughts?
