Shop Scholl Concepts Purple Spider Pad
The Scholl Concepts Purple Spider Pad is a new generation of intelligent polishing pad which combines the advantages of foam with the cooling features of natural lambswool pads. Its calibrated three-dimensional surface results in a higher cut and better endurance of abrasive particles. The reticulated foam gives a higher air circulation, is designed to resist any tearing or deformation, and creates less heat generation when polishing, allowing the speed of the machine to be increased to reduce polishing time. Due to the center hole this foam resists "foam collapse" at its core allowing use on the new generation long throw dual action machines as well as both traditional D/A and Rotary polishers. Best of all, paired with the correct polish, the finishing ability of this pad is incredible making one step jobs a reality in many cases!
Specifications:
- High strength tear resistant foam
- Center hole to avoid "foam collapse"
- Higher Cutting Rate
- Less Heat Generation courtesty of calibrated Spider cuts
- Specifically designed to compliment the Scholl Concepts range of Compounds
- Suitable for Dual Action or Rotary Polisher
Specifications:
- Made by Scholl Concepts in Germany
- Cut: 5/8 Good
- Finish: 6/8 Very good
- Material: High strength reticulated foam
- Polishing Face Diameter: 5.7" (145mm)
- Thickness: 1"
- Hook & Loop Diameter: 5"
- Color: Purple
- Velcro Color: Black
