Tyler@HDR
When a client of mine reached out asking for his show vehicle, a 1968 Camaro SS to be polished and waxed, I knew I was going to have to source out a fantastic wax to top this incredible car with.
I decided to use the wax in this review - they OBSSSSD Show Wax by Swisswax.
Unfortunately, I did not take many photos during the process due to time restrictions on the job - but I did keep track of the notes that I will condense into a short review
Manufacturer Claims
"Swissvax OBSSSSD Luxury Carnauba Show Wax is a high content Carnauba show wax containing 68% of yellow and non-bleached Grade One Carnauba wax from northeastern Brazil by Volume. Specially created by hand in our manufactory at the shores of Lake Greifensee for OBSSSSD Corp., Canada, this pleasantly fresh formulation, enhanced with oil extracts from passion fruits and apricots creates impressive `soft` reflections (specially on dark and non-metallic paintwork) making this high carnauba content show wax one of the most forgiving waxes on the market. Excellent beading and sheeting capabilities was achieved by composing hard waxes as a catalyst to create an extended durability in difficult climatic regions."
Product - Sights, Smells & More
For some, the smell of a wax is very important - and this wax will not disappoint. It has an extremely rich, pleasant fruit scent that is (bluntly put) intoxicating (and lasts for long after application). Visually, nothing to note. It`s not a soft wax, and is harder and has a slightly `gritty` texture to it. Because of this, it does mean it can crumble a bit more than expected, but nothing that causes concern during application. I found having the wax warm / room temp prior to use remedied any crumbling issues that could potentially arise, even though I did not experience these anyway.
Application
Application is a breeze. As the texture is a bit gritty and the wax quite hard at first, it does take a bit more to `prime` an applicator pad than other waxes. Again, a small detail but one to note. I found that rubbing the applicator in the wax, `warming` it, helped significantly with this. It should be noted once the applicator is primed, the wax goes a LONG ways. The small 50ml pot I used could easily treat 2-4 vehicles with a couple of coats per.
For the application process, I first primed the pad, then applied in straight back-and-forth lines as per the manufacturer recommendation. This worked well, and spread the product thin and evenly. I was able to apply the wax to the entirety of the vehicle before beginning removal, which was a 12-16 minute venture (roughly). I believe that I could have waited even longer, as the wax is extremely forgiving in this area based on my testing in other controlled and non-controlled environments.
Removal was incredibly easy - more than I imagined it would be. Using a wax removal towel (I suggest Swissvax), the wax came off smoothly with one wipe. I did give a second pass on a fresh side in case I missed any areas, but to my surprise the wax left very little to no residue-spots like I have experienced on other waxes. There was no greasiness during removal, nor was there any dusting present. A great feat to accomplish both to the extent it did, as most waxes fall short in one area where this does not.
Additional coats were applied 12 hours after the first coat. Note: I find having three (3) layers on the paintwork brings out the gloss and `wet` look best. I haven`t exceeded 3 coats yet, but did find that while a single coat did look amazing, having those additional coats brought on a depth and shine that blew me away. It has a soft, yet rich and `deep` wet look that truly looks like wet wax just pooling on the surface.
DARKENING - Yes this wax WILL darken black paintwork. This was confirmed on another clients vehicle where we applied (3) coats to the hood of the vehicle, and were able to visually see the difference in paint depth and black levels between the sides waxed, vs non-waxed. We even tossed a couple other waxes on the other side to see how they would compare - and while they did darken the paint as well with a couple layers, none of them touched the rich darkening and glossy appearance of OBSSSSD.
Results
Beading and sheeting was what is to be expected - fantastic, tight beads that easily slide off the surface with a little wind or driving. Nothing you haven`t seen before - but it will definitely be near the top of your list in terms of beading characteristics and overall sheeting capabilities. Often I find many people believe beads are the best - which sure, they look great - but I want sheeting; this wax sheets and releases water incredibly easy... even more-so than many of the professional coatings I use!
You may notice that I did not comment on durability on this review - this is because durability is not the purpose of this wax. It was designed specifically to enhance finishes on vehicles that require the best appearances money can buy - and as I have tried various waxes in similar price brackets, I am confident this is by far the best of the bunch thus far. However, I have applied it to other vehicles that I did not see for ~5 months, and beading was still strong!
In conclusion, I cannot stress enough the impressiveness of this wax. It has what many will think is a high price tag, but in real-world applications, it holds its own and performs exactly, if not better than the manufacturer claims, making it worth every penny. The appearances far exceed other premium waxes I have used in the past (Swissvax, Zymol, Griots, Pinnacle, etc)., and looks absolutely fantastic on darker colors. I have yet to try it on lighter colored vehicles, but cannot wait to try. The beading was on point and very strong, holding up over months of casual driving, and even repelled dust more than expected for such a high carnauba content wax.
Thanks for reading, and let me know if you have any questions. I would be happy to answer them based on my experience with the product!
- Tyler Hoffarth
Manufacturer Claims
Application
Results
- Tyler Hoffarth
