D
Detail2Correction
I've been wanting to do a comparison of what I call "The big 3" for a while now but haven't. I feel that I have finally reached a point were I can give an accurate, honest account of each compounds performance.
I have read many reviews on each compound but each was lacking something; either proper pad priming, work time or pad selection. In each review I felt if something was done just a little different it could have improved a particular compounds results.
From my experience and reading FG400(like most diminishing abrasives) doesn't do well with microfiber pads. Yes it cuts but the work time is short. However if you do use a MF pad use a finishing pad because the amount of heat FG400 generates on a cutting pad is down right dangerous on the Rupes 21.
I have also found that M101 and M100 work very well on Meg's MF finishing discs. With SMAT heat doesn't seem to be as much as an issue as micro marring is.
It wasn't until about two weeks ago I found a foam pad that I absolutely loved. A pad that was on the same level as a MF pad. It was then I felt I could do a really good comparison between "The big 3". Thanks to Corey Caruth and Wes Walz I found the Scholl Concepts white Spider pad. It's unlike anything I've ever used before which I think will be shown later.
The hood on my 2000 Firehawk will be repainted soon due to paint adhesion problems thanks to SLP's crappy paint program, so I had a test panel.
(I forgot to take an over before pic of the hood, this is after)
The entire hood looked like this.
The test was setup up as scientific as I could get it, lol
Car was washed with car shampoo/dawn/APC to strip any LSP's, Iron X, clayed. Hood was wiped down twice with Eraser. That's when the previous pic's were taken.
Products
Rupes 21 was used on all sections
1. Scholl Concepts 5 1/2 white spider pad and FG400
2. Meg's M100 and Meg's 5 in MF finishing disc
3. Meg's M101 and Meg's 5 in MF finishing disc
Priming
One of the biggest problems IMO with some of the reviews I've read is proper pad priming. Priming a pad using diminishing abrasives is completely different than using non diminishing abrasives or in this case SMAT.
This is how I primed the spider pad with FG400. If I were to continue to use this pad after this section I would use three pea size drops only.
For SMAT I use the Kevin Brown Method on both microfiber and foam. Kevin has been a great assist to me and is always there when I have a question. Using the "KBM" drastically reduces dusting and increases work time. This is the way I prime the MF pad using both M101 and M100.
Work all of the compound in and you get this.
Blow that out with compressed air and put three good pea sized drops on. I find I normally have to add a little bit more when using M100.
Polishing
1. Spider/FG400: 3 passes on speed 4, moderate pressure. 3 passes on speed 3 light-moderate pressure. Compound should be completely broken down.
2. Meg's MF finishing disc/M100. 3 passes on speed 3. moderate pressure
3. Meg's MF finishing disc/M101. 3 passes on speed 3. moderate pressure
When using the methods above I get zero dusting from any of the compounds. I know some people have problems with M101/M100/M105 dusting even on MF. I have found using anything higher than speed 3-3.5 will cause dusting due to the extra heat and cause the lubricants/transport agents in the compounds to dry out.
Due to the design of the spider pad and how it stays cool the work time especially with FG400 is insane. I had no idea that FG400 could break down as fine as it does. It's an absolute joy to watch and work with.
Results
1. spider/FG400
M101 and M100 did not show any more heavy defect removal than the spider/FG400 combo did. However M101/M100 showed a tremendous amount of micro marring compared to the spider pad/FG400.
I've been a huge fan of Meguiars and their SMAT products and MF pads. For me to say that I'm really impresses with the Spider pad and FG400 is a really big thing for me.
I'm sorry I don't have any better lighting shots but I'm by myself tonight and all I could use as my Brinkman.
The products and process listed above are things that work for me. In no way do I think or claim these are the only way to do things.
Feel free to post any comments positive or negative.
Jason
Products
Priming
Polishing
Results
1. spider/FG400
Jason
