CarPro Flash Pad 6 1/4"
Introducing the Amazing Flash Pad... Defects removed in one pass! Click here to read more!
Extreme Cut!
Extremely Durable
Reticulated Polyurethane Foam
Bevel profile
High Grade adhesive
Velcro backing
Specifications:
Made in: France
Material: Reticulated Polyurethane
Polishing Face Diameter: 6 1/4"
Hook & Loop Diameter: 5 7/8"
Thickness: 3/4"
Color: Cream
Velcro Color: Royal Blue
Velcro Peel Strength (Dry) N/25mm: 16
Velcro Peel Strength (Wet) N/25mm: 13
Tensile Strength: 330 kPa
Ultimate Elongation: 135%
Cell Count: 73 ppi
Density kg/m3: 37
Cut: 8/8 Intense
Finish: 6/8 Good
Polishing Tips:
Fasten pad to machine taking care to securely center it on your backing plate
Follow polish dependant tips
Avoid overworking an area and do not hold pad still in one place
When polishing, clean your pad after each section with your Foam Pad Brush before applying a couple more drops of polish for the next section.
Extreme Cut!
Extremely Durable
Bevel profile
High Grade adhesive
Velcro backing
Specifications:
Made in: France
Thickness: 3/4"
Color: Cream
Cell Count: 73 ppi
Density kg/m3: 37
Cut: 8/8 Intense
Finish: 6/8 Good
Polishing Tips:
