Reflect by hand
  • Thread starter Thread starter k1ng
K
k1ng
Hi, is it possible to use Reflect by hand to remove some light swirls? Understand it will take longer than D/A but in general how long it'll take to hand polish light defects using Reload? And should I use finishing pad (e.g. B&S black)or light cut pad (e.g. B&S blue)?
Thanks
K1ng, Your question is a little difficult to answer. First off, not all clears are the same (some softer and some harder). Second, light swirls to you may not be light swirls to someone else (including a pro). A test spot is always recommended to dial in your process.
Is it feasible to remove defects by hand?? ABSOLUTELY, but I would tell you that you more then likely will need to step up to a little more aggressive polish than Reflect (unless you want to spend quite a bit of time). I would recommend that you get a GG6 (Griot Garage). It is very "new comer" friendly and will have future use (such as machine waxing/sealing). A great investment in my opinion.
Fixer and Reflect are actually as good as it gets for hand polish imo as they break down fast BUT dr P is right of course! I would never attempt to do more then under the door handles by hand. Way too much work.
